PA 1993 Civic Si 11.3@125 Full-Race, Koni, etc.
Selling my 93 Si hatch. I've had it for about 10 years. It was tuned to 406 whp, 285 ft lbs. @ 14 psi on a stock LS bottom end. Tuned by Jeff Evans on Neptune. Consistently ran 11.3@125 mph w/ 1.7 60 ft. There are only quality parts on this car.
$8750
Here are the mods:
Engine:
Stock LS bottom end
GSR head with Comp/Zex springs and retainers stock port
GSR cams
Edelbrock Victor X intake manfold
GSR throttle body
Skunk2 cam gears
PWR radiator with stock shroud
Golden Eagle head studs
Energy Suspension mount inserts
Injector Dynamics 1000CC injectors
B&M fuel pressure gauge
Walbro 255 fuel pump
Trans:
GSR with ITR LSD 4.4 gearing no grinds
Spec Stage 3 clutch
Stock axles
Turbo system:
Full Race Pro Street T3 Manifold
T3/T67 HO P-trim .82 AR turbo
Tial 38mm wastegate
Greddy Type S BOV
Greddy Profec B boost controller
Greddy turbo timer
Precision 750 hp intercooler
Custom 2.5 IC piping with high quality Clampco T-bolt clamps and 4 ply couplers
Full Race 3" downpipe
3" Stainless test pipe
Thermal R&D 3" exhaust system
GM 3 bar map sensor
Neptune
Suspension/brakes:
Koni Yellow/ Ground control coilovers 550/450 rates
Stock front sway bar
SRR rear lower control arms (limited one off color)
Energy suspension steering rack bushings
DC2 Integra front brakes
1991 Civic EX 15/16ths brake master cylinder
Stock Si rear brakes
Kosei K1 15x7 38mm offset
205/50/15 Falken Azenis
Miscellaneous:
JDM EG6 SIR 1 piece long LED wing
Momo steering wheel
Stock Si interior
Kenwood head unit and Eclipse speakers
No ac or power steering
Extras this car will come with ONLY FOR ASKING PRICE:
Two spare LS blocks and cranks
One sleeved LS block (Darton sleeves maybe?)
81.5mm JE pistons and Eagle rods for B18B lightly used
Lenso 13" front drag wheels with 24.5x8x13 M&H slicks
I used to drive this car to many different tracks, bolt the slicks on, run low 11's and drive home. All without a hiccup. This car is capable of going ALOT faster by simply putting a built shortblock in it and re-tuning for more boost. The parts to do this are included if I get my asking price.
Please don't waste my time or yours. NO TRADES.
More pics will be up soon
$8750
Here are the mods:
Engine:
Stock LS bottom end
GSR cams
GSR throttle body
Skunk2 cam gears
Trans:
Spec Stage 3 clutch
Stock axles
Turbo system:
Tial 38mm wastegate
Greddy Type S BOV
Greddy turbo timer
GM 3 bar map sensor
Neptune
Suspension/brakes:
Miscellaneous:
Momo steering wheel
Stock Si interior
highmilehatch
Northeast (Sales)
Nov 30, 2012 12:15 PM
InDub
Jun 3, 2006 05:54 AM
