Bad performance with map sensor
I have a honda civic EG with a b20b motor, CEL came on and showed code 3 map sensor. I replaced map sensor....the cel went away but the cars performance is really bad...the idle is very low with the map sensor connected and the car dies after revving it up but the performance is basically the same without it, once I disconnect the map sensor there are no issues, the car can rev up and drive normally but my understanding was that the map sensor was supposed to give the car more power and better performance this is just through some research that I have done. I dont know much but learn something new each day with my research. There is a piece of cloth in the throttlebody lower port, I've noticed that once I remove this cloth the cars idle is really low and if I try and revv it, it kinda has a miss...the car is normal with the cloth and without the map sensor connected. pls give me advice on this.
Check for swapped sensor connectors by verifying that wire colors in connectors match to the sensor.
Permanently remove the cloth. Does the blocked port lead to an FITV or IACV or does the cloth hold the throttle plate partially open?
Sorry for my late response, I have limited access to the internet...I checked the connectors...it looks like the map sensor and tps are both correct with there wire colours. I think the block port leads to the FITV if I am correct I have done some research. When I remove the cloth... the map sensor connected with no cel the car has a misfire.The throttle plate is fully closed.
yes I asked them to show me that its working...what did was started the revved it, revved fine and after that while the car was running disconnected the map sensor...the car could not rev up it wanted to die off so I knew the sensor was working.
Hi Guys, I remove the cloth, there is a misfire and the engine shakes badly I remove the connectror plug to the map sensor and the misfire is gone the rev stays at 1500rpm and once the car is warm it goes to 1000rpm every 2seconds,the car drives normal but there is no power no cel coming on.Can someone please assist with this I would really like to get this sorted.
