Who can chip my p28???
Old Nov 25, 2012 | 07:46 PM
V-tec_91_Hatch's Avatar
Icon2 Who can chip my p28???
im new here and i need to be pointed the right way i have a p28 and i know that i need to get it chipped with a d16y8 basemap for my setup... can anyone please point me to someone who can do this for me....
thanks in advance Jorge
Old Nov 25, 2012 | 08:03 PM
91legend's Avatar
Default Re: Who can chip my p28???
I don't think this is the right place but, you can take it to a performance shop.
Old Nov 25, 2012 | 08:06 PM
sorry if its posted in the wrong section im new and im getting used to thiss place lol
so any good performance shop should be capable of doing this i guess?
thanks for the quick reply Jorge
Old Nov 25, 2012 | 08:19 PM
91legend's Avatar
That's what my buddy did when he got his P28 chipped with S300
Old Nov 25, 2012 | 08:27 PM
Canadian_EF's Avatar
Phearable.net or Xenocron can do it.
They both do pretty much the same thing so it's whichever you choose.
Old Nov 25, 2012 | 08:56 PM
thanks for the help guys... so like you said on my other post would the z6 cam gear work insted of chipping it or will i be better off by chipping it with the y8 basemap?? thanks again!
Old Nov 25, 2012 | 09:19 PM
i've never tried it, it's merely something i had read about. the y8 basemap is much easier and gives you launch control which is pretty neat.
if you use the z6 cam gear, you're on your own... I want to try it when I get my b16 going lol.
Old Nov 26, 2012 | 03:36 PM
ennah's Avatar
Pherable.net or Xenocron. Or someone local to you
Old Nov 27, 2012 | 04:21 PM
ok so i opened my ecu today to check why i was having problems and i find this....
top view
closeup
is this fixable?
Old Nov 27, 2012 | 08:41 PM
moejoepotatoe's Avatar
I know nothing about electronics but I know that you know that can't be good lol. Do you have driveability problems?
Old Nov 27, 2012 | 08:50 PM
heres my other post wich explains whats happening im frustrated at this point.... all i want to know now is if this could be fixed :/ if not ill have to get a new one.....
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/91-dx-hatch-d16y8-p28-need-help-runs-bad-crook-3106130/
Old Nov 28, 2012 | 07:35 AM
mtber's Avatar
q31 being burnt won't usually effect drive ability. q31 controls evap.
When q31 is burnt on the ecu, you likely mixed up evap and intake air temperature sensor engine harness plugs in the engine bay. Your intake air temperature sensor is likely damaged.
Verify your intake air temperature sensor wiring & inspect/replace the sensor.
Old Nov 28, 2012 | 10:00 AM
thanks and i wasn't me it was the previous owner of the ecu... he probably had wiring problems....
Old Nov 28, 2012 | 03:48 PM
ok so i kept looking for y problem cause obviously Q31 wasn't it because i don't have evap in my hatch.... so looking around i find this
here is a pic of both of the things Ive found...
would this be the problem im having guys? Thanks!
Old Nov 28, 2012 | 09:50 PM
swordofdoom's Avatar
Yeah that could amount to a lot of problems you have two choices here. Replace the ECU with a good one or you can buy the components that are fried out, re-solder them on and trace the circuits that are fried out and install a small wire to where ever they go. I don't recommend option 2 since it requires extensive skills to trace and replace
Old Nov 29, 2012 | 09:17 AM
thanks you very much i will be looking for a new one soon
hopefully this time not burnt...
Old Nov 29, 2012 | 03:38 PM
Rusty94cx's Avatar
you can send me the bunt one I ll pay postage. father in law is electronics repair tech so all is good. pm me and let me know.
Old Nov 30, 2012 | 09:59 AM
im not going to give it away sorry im going to attempt to fix it...
Old Nov 30, 2012 | 04:23 PM
ennah's Avatar
The cap in the lower left corner can be replaced. Most likely it leaked on the board. Clean and inspect the area around it. Q31 makes no difference if its blown or not.
Old Nov 30, 2012 | 07:07 PM
thanks so do you know what the cap does??
felipe69
Mar 21, 2008 08:49 PM
brookliner7
Feb 2, 2005 05:38 AM
99B16Si
Feb 24, 2004 07:30 AM
