cam cap bolt broke help !
make a starting point and start drill with a small drill then with a little bigger try not to damage the threads if you damage them use helicoil.
it's all up to you.
it's all up to you.
you are doing something very wrong! that 10mm bolt should only be torqued to like 8 ft lbs how the hell did you break it! do know they have different torque specs?
Best bet is to use a bolt extractor kit.
spidermancivic
Oct 3, 2006 09:41 PM
The Destroyer
Feb 19, 2005 01:47 PM
B16CRXT
Jan 31, 2004 09:20 PM
