90 sedan/b18a swap - pass radius rod is right on my tranny
i have a 90 sedan wtih a b18a and my pass radius rod is right on my tranny when i slam my car down only way it doesnt hit is if im up about 2inches from bottom on my tiens. My question is do they make an aftermarket radius rod for the b series application or am i stuck fabricating one
if your mounts are good then maybe you should not be dropping the ride height ALL the way down...if you have to do that for some unknown reason then you probably will have to fabricate it.
b20vtech
Nov 7, 2008 04:37 PM
