91 crx/d15b2 -- motor mount snapped
Old Nov 23, 2012 | 05:05 PM
timmie124's Avatar
Default 91 crx/d15b2 -- motor mount snapped
So today right as I was pulling into my drive way my motor mount snapped
I don't need any help replacing these I just don't know the name of the part that snapped, I googled around throwing out different names and couldn't find it. and My local part store doesn't carry this part
Old Nov 23, 2012 | 05:17 PM
Former User's Avatar
Default Re: motor mount snapped
You need to post your car and engine.
Old Nov 23, 2012 | 06:05 PM
timmie124's Avatar
d15b2 91 crx
Old Nov 23, 2012 | 06:26 PM
Ash J. Williams's Avatar
Good, Bad…I'm the one with the gun
From: Trapped in time, Surrounded by evil, Low on gas
i had the very same problem happen to my CRX, the transmission mount plate ripped in half, you won't find it at a parts store, go to a wrecker and ask for the transmission mount with the plate attached (they come that way anyway from the junk yard). you can then replace the mount with a new one, reusing the plate.
is your clutch aftermarket? do you have stiff aftermarket mounts? does your clutch chatter?
Old Nov 23, 2012 | 06:40 PM
4drEF's Avatar
Keyboard Humorist
I think what the pictures show to be broken isn't the mount, but the bracket that the mount bolts down to.
#7 in the image from the link
http://www.hondaautomotiveparts.com/...5=ENGINE+MOUNT
Old Nov 23, 2012 | 10:47 PM
Bently_Coop's Avatar
Steve at Heart
4dr is right, had a similar problem on my 89si
Old Nov 24, 2012 | 09:35 PM
timmie124's Avatar
Default Re: 91 crx/d15b2 -- motor mount snapped
ok so i found a honda wrecking yard and got the part for 15 bucks just gotta wait till monday to pick it up. I also noticed this, idk if this is screwed up from the bracket snapping or if the last owner just didn't mount it
Old Nov 25, 2012 | 09:23 PM
4drEF's Avatar
Keyboard Humorist
That is your front transmission mount being not bolted at all.
From the link in my previous post, you are missing a bolt, washer, and a special nut.
#18, 22, 12
Without that mount, the added stresses translate to the other mounts.
No doubt that it helped your bracket break.
A lot of people skip out on the front mount.
The bolt is typically a pain to get to.
I've always had to remove the exhaust manifold to get a clear shot at it.
It looks like the bracket is bent pretty badly.
Maybe from the engine and transmission torquing around or maybe from the previous owner banging it out of the way with a hammer.
I would try bending it back into place so you can put a bolt through it.
Or get a new cross-member - the bracket is welded to the cross-member.
Dkahn18
Oct 23, 2008 05:37 PM
91slamedrex
Jul 6, 2006 07:01 PM
94gsrhatch
Nov 20, 2004 05:35 PM
dutchman5
Feb 6, 2003 12:48 AM
