Lets talk fuel filters. and OEM's quality
I serve phở for my babies
What micron does the Oem 92-00 civic fuel filter, filter down to? ID recommends I have a 10 micron filter for my injectors, my set i just had cleaned had one injector go bad because of debris. I don't want this to happen again, they only have 10 micron Weldon filters which are ~$90 a piece, i still have stock lines up to my fuel filter then AN to the rail and then to the regulator.
What's the stock fuel filter micron rating? if it's more than 10, what's a small and easy filter i can mount on my fuel rail that's not the size of a coke can that's compatible with e85 and isn't ridiculously priced?
There are millions of cars on the road today with OEM filters. They work fine. The issue may have been a rip or tear in your original filter, particularly if you were using Honda OEM with e85 fuel. The are not compatible as Honda has not needed to use this fuel fad to improve sales. Your options are after market or another OEM filter that may work and is e85 compatible(GM, Ford...etc)
