Northwest Alaska, Idaho, Montana, Oregon, Washington, Wyoming
Integra stolen 11/23/12
Old Nov 23, 2012 | 12:17 PM
R.sok's Avatar
Default Integra stolen 11/23/12
STOLEN!!!!!!
My brother uses my car to take to work & this morning it got stolen in the auburn/federal way, wa industrial area
-License plate number ahd8208
-95 black Integra
-98-01 front & rear oem bumpers
-17 inch enkei rct1
-Rotora 4 pot BBk
-Itr exhaust
-itr lip
-2 1/2 grey greddy piping
-dented to **** 4-1 header
-adjustable 2 1/2 test pipe
-b18b
-b16 transmission
-rsx seats/driver ripped
-momo wheel & hub
-airbag delete tray
-any info please call the police department or 253-753-5991
Old Nov 23, 2012 | 04:01 PM
Mugen Fan's Avatar
Default Re: Integra stolen 11/23/12
sorry for your loss, karma will get them.
Old Nov 23, 2012 | 10:08 PM
HOMEMADEPOWER's Avatar
F##king thrives. Hope you find your car brah.
Old Nov 24, 2012 | 01:21 AM
HuiDC2's Avatar
Originally Posted by HOMEMADEPOWER
F##king thieves. Hope you find your car brah.
^^^this
Old Nov 24, 2012 | 02:44 AM
TypeRfit's Avatar
RESIDENT
Sorry to hear that, that was a clean Db. Hope you find it in 1 piece.
Old Nov 24, 2012 | 01:21 PM
drmix's Avatar
Ill keep an eye out since I am always in the Auburn/Federal Way area
Old Nov 24, 2012 | 07:09 PM
R.sok's Avatar
Thanks. I do have a distinctive set of brakes on my car & as far as I or any of my friends have yet to see another set locally.
Old Nov 28, 2012 | 11:56 AM
DC206R's Avatar
Those wheels aren't super common either.
Old Nov 30, 2012 | 11:08 AM
bankonyourself's Avatar
bump. f*ck thieves!!!
Old Nov 30, 2012 | 11:34 AM
White95SiHB's Avatar
f thieves, I know what you're going through.
What kind of anti-theft measures were on your car?
Old Nov 30, 2012 | 09:12 PM
R.sok's Avatar
Thanks the wheels have silver paint chipping around the lip so white shows & they have an off brand set of new 205/40/17 tires.
The lip of the rims exceed a little past the tire so it looks kind of wierd & one of them have a noticeable bend on the lip, While the others having tiny bends on the inside lip(was going to get them all refinished over the winter).
Cluster is the original gsr but I stripped out the inside lighting & installed 2ft of white led strips so no hot spots & the needles I removed the original color & painted a see through yellow. (rpm needle has a crack right where the cap covers)
Bezel has one hole for the alarm light in the middle & a couple random screw holes that once mounted a shiftlight.
Door panels are I believe an optional leather door panel with nice cushion...I havent seen another set in black locally...they each look like this but this picture is off a 2 door ( http://hondamarketplace.com/showthread.php?t=2606406 )
with the rear driver side that has a tare kind of by where the middle curve is.
momo steering wheel that is faded (full size) but everyone has those however my momo hub has a little scrape mark (chunk) missing so you see a little bit of silver.
Headlights..driver is in great condition, passenger side has built up condensation on the inner lower lens that can't be removed unless you remove the lens.
Airbag tray..abs plastic, but everyone has those so I won't be able to identify it.
Rsx front seats, passenger in good condition, driver side has a tare on the lower cushion with the right side of the driver bolster having a slight rip & they both have modifications to the rear with welds to allow the seats to bolt up on all 4.
Big brake kit Rotora 4x100 12.9 inch rotor/4 piston-havent seen another set locally.
Adjustable three piece test pipe 2 1/2. On one of the pipes I cut some material off because my header was too long & i wasn't worried with making a perfect cut so it's pretty obvious when you pull it in pieces.
greddy 2 1/2 mid pipe..I painted it kind of like a metallic dark grey with spray paint..lol. The resonator has scrape with two spots that I puttied.
Itr exhaust..The piping & flange of it is connected with random ugly autozone pipe extensions & screw type clamps, with the inlet being a reverse donut 2 1/4 inch size. I have the 2 1/2 piping but never had it installed..got lazy.
Front struts are adjustable & rebuildable Ohlins (again not something you see everyday) I was in the process of getting them rebuilt over the winter, they have cheap ebay coilovers on them.
Driver side bumper has a chunk of paint missing from a lady who did a hit & run. I was going to repair it in the summer.
Front lip is polyurethane & i drilled random holes on the bottom to have multiple zipties holding it from the bottom.
When the lady hit & ran me my driver side fender got damaged & all i had was a fender that had a sidemarker slot, so i painted it & threw it on. so one side had a side marker and the other doesn't (was planning on getting a different fender but I was in no rush as It started to get cold so I couldnt paint till next year unless i rented a booth)
Corner lights..passenger has a slight white glue residue on the exterior & the driver side was resealed by a hazy clear sealant.
My car was not perfect by any means, it had flaws that you could notice if you looked up close. It was my little bucket project & my first car that I've ever painted. I was planning to paint the car every year until I could get really good as a hobbyist. All parts still needed to be cut & buffed by me but I got lazy as it was getting cold so some parts do have orange peel & i do have minor runs on each door that never bothered me.
For security I had an alarm & two kill switches that were not connected directly to the fuel pump in the rear (like most). I let my bro take my car to work & I've been there before. I believe it was either an inside job or someone that works nearby him that has been plotting...if you were driving on the main road you would not be able to see his work place without driving all the way towards the end. Car was stolen from 7am-9am on a foggy morning
Old Nov 30, 2012 | 09:17 PM
R.sok's Avatar
I replaced this fender with one that has a side marker whole however I never got around to redoing the bumper..as you can see some paint chunks came out when the lady hit me
Old Nov 30, 2012 | 09:18 PM
R.sok's Avatar
Old Nov 30, 2012 | 09:20 PM
R.sok's Avatar
Also I had a front (blue) license plate frame that represents (washingtonlakes.com) fishing forum..maybe someone seen something like this down the road? idk
Old Nov 30, 2012 | 09:22 PM
R.sok's Avatar
http://sphotos-a.xx.fbcdn.net/hphoto...40488133_n.jpg
Old Dec 1, 2012 | 07:09 AM
Slomo_civic's Avatar
Sorry to hear about this. Side note though, the cluster looks good!
Old Dec 1, 2012 | 07:16 AM
tsxpert's Avatar
Any luck yet?
Old Dec 1, 2012 | 11:47 PM
R.sok's Avatar
No luck & have seen nothing posted up parts wide on neither craigslist nor ebay
R.sok's Avatar
parts wise*
LiveFastDieFun
Northern California
25
Sep 16, 2009 12:01 PM
yoitz2tone
Feb 26, 2009 07:59 AM
RicharDC4
Sep 18, 2008 03:31 AM
ATS*Mark
Jun 22, 2004 11:51 AM
