Oil Leak Behind Crank Pulley
Old Nov 22, 2012 | 04:38 PM
Mr. Future's Avatar
Default Oil Leak Behind Crank Pulley
Long time reader, first time poster. Just learning how to break cars on my own. On my 2000 Civic CX, D16Y7 engine (108K miles), I have a slow oil leak a few inches aft of the crankshaft pulley.
Which gasket/s should I replace? I just replaced my distributor o-ring. Should I just go in and replace EVERY gasket? Thanks for your time.
Old Nov 22, 2012 | 04:48 PM
slowturbocx's Avatar
Default Re: Oil Leak Behind Crank Pulley
It is the oil pump seal. Take the pulley off then the belt and gear. replace seal or entire oil pump(which wouldn't be a bad idea.)
Old Nov 22, 2012 | 05:35 PM
Mr. Future's Avatar
Thanks. Are there any other gaskets I might as well replace "while I'm in there?" I have 40K on my timing belt - should I replace that, too?
Old Feb 5, 2013 | 08:36 PM
NaturalTone's Avatar
bump replace timing belt and water pump while your at it...its the oil pump seal for sure.
Old Feb 6, 2013 | 11:23 AM
giovannie23's Avatar
yea i had the same problem i changed the o.p seal and cleaned all that up oil off and havent noticed any leaks so far.
Old Feb 6, 2013 | 11:29 AM
MaxisCy's Avatar
if any oil has gone onto the T belt replace it. Not a bad idea to replace all seals once you are at it
xyzbytes
Honda CR-V & Element
Mar 6, 2019 11:03 PM
pootie.teng
12
Mar 22, 2007 09:09 AM
immalooser
May 17, 2006 03:27 PM
crxdriver89
Mar 13, 2006 01:49 PM
ludelvr
Dec 19, 2003 11:01 AM
