98 civic lx - cel doesn't work
Old Nov 22, 2012 | 04:25 PM
termite1r's Avatar
Default 98 civic lx - cel doesn't work
I have a 98 civic lx and i just realized that the cel doesn't flash when i first turn the car on. Is that normal? All other cars i know of hace the cel come on for a couple seconds when the car first starts.
Old Nov 22, 2012 | 04:27 PM
grumblemarc's Avatar
The Grumpiest
Default Re: help please pretty confused
Is there a bulb in the cluster?
Old Nov 22, 2012 | 04:29 PM
CO671's Avatar
Probably the bulb was removed to mask a problem, or the bulb is just plain burnt out.
There will be only 6 screws to remove, check it. 2 on the cluster guard, 4 for the cluster itself.
Old Nov 22, 2012 | 04:37 PM
termite1r's Avatar
ohh ok thanks you guys
I was really confused by it so ill check it tomorrow as sson as there is daylight
is there a specific bulb i might need?
Old Nov 22, 2012 | 05:03 PM
CO671's Avatar
I believe it's a #74
Old Nov 26, 2012 | 09:05 AM
termite1r's Avatar
Default Re: 98 civic lx - cel doesn't work
awesome I got the bulb and yes the CEL is on
the scanner said its a bank 1 sensor 2 which I'm assuming is an o2 sensor.
Old Nov 28, 2012 | 03:44 PM
NOFX's Avatar
H-T White Ops
There should also be a code that goes along with the "diagnosis". This code should be universal and you can search for it online to find a description of what it means. The code should start with P0 and have three numbers after that.
Old Nov 30, 2012 | 11:52 AM
termite1r's Avatar
its P0141
Old Nov 30, 2012 | 12:01 PM
zerovandez's Avatar
That will be your secondary o2 sensor, after the catalytic converter.
Old Jan 25, 2014 | 07:56 AM
termite1r's Avatar
Sorry I took long to update the post. I have changed both sensors and replaced the catalytic converter and reset the ecu but the same codes still pop up. Im thinking it mightvbe a wiring issue instead
Old Jan 25, 2014 | 01:39 PM
CO671's Avatar
That, or your exhaust manifold is cracked. Double check the manifold for cracks
Old Jan 25, 2014 | 06:18 PM
termite1r's Avatar
The converter was a 2 piece exhaust manifold with the converter. When i scanned the ecu after i replaced the parts it said that those parts were not registered with the ecu
dh1212
Apr 30, 2016 12:35 PM
EG6 Love
Engine Management and Tuning
Oct 14, 2011 05:45 AM
mikej94civex
Dec 15, 2009 01:18 PM
Chipped B6
11
Feb 24, 2009 09:25 AM
LSpimpTEC
Jul 29, 2004 09:09 PM
