AC belt help
Old Nov 22, 2012 | 03:26 PM
chaddydaddy's Avatar
Default AC belt help
Just bought a 97 accord 4 cyl. 2.4 liter, non vtech. The AC belt squeals and is obviously too loose, but I cannot find the adjustment for it. Any help would be appreciated.
Old Nov 22, 2012 | 09:34 PM
Hidenplanvew's Avatar
Default Re: AC belt help
Best advice I can give you is get a Helms, best 25 bucks you can spend.
Old Nov 22, 2012 | 10:37 PM
holmesnmanny's Avatar
lol 2.4 liter. I assume that's at typo. It should be the same as mines. You loosen up the 14 mm size through bolt at the top. Loosen up the 12mm size nut that runs through the adjuster bolt. It points in the same direction as the 14 mm. Then tighten the 10mm bolt that runs perpindicular through the bolt that the 12mm nut goes through. This will pull the belt tighter. You basically want it tight enough to where on the longest side of it you can twist it and it doesn't turn more than 90 degrees. Then tighten back up the 14mm and 12mm again. The 12mm doesn't really need to be that tight, it's the 14mm that you tighten down decently.
the king.
Feb 15, 2013 12:26 PM
Panoply
Aug 6, 2008 08:33 AM
Schultzie
Aug 5, 2007 07:44 PM
essenz
Feb 7, 2005 10:22 PM
PerfectXtreme
Aug 2, 2003 10:41 AM
