A/C doesn't work
Old Nov 18, 2012 | 05:56 PM
DelSol06's Avatar
Default A/C doesn't work
Wassup guys i have a 1994 del sol si the ac doesnt work and theres a loud buzzing/humming sound when the car is idling but when i step on the clutch the noise stops any ideas or suggestions?
Old Nov 18, 2012 | 06:52 PM
cascanjepp's Avatar
Default Re: Help with my 93 del sol
maybe the compressor?? Where is the noise coming from
Old Nov 18, 2012 | 08:04 PM
DelSol06's Avatar
Near the timing belt area i think its the compresser but im not sure
Old Nov 18, 2012 | 08:30 PM
B20DelSol's Avatar
That sound is your input shaft bearing in your transmission. Honda released a TSB regarding the noise in the D-series trannies claiming that it "is a bad design". If it is horrible and metallic sounding, then it needs to be replaced, but if it not too bad, it is just normal.
(you just thread jacked us, but its cool ).
As far as your AC...warm the car up to operating temp and turn the AC on full blast. Now check to see if the Compressor clutch is engaged and spinning. If so, have the refrigerant pressure checked and you may need to have the system recharged at the very least. If the AC clutch does not engage, it may be the AC button, relay, or clutch.
Old Nov 18, 2012 | 08:50 PM
DelSol06's Avatar
My bad guys im new to this site the ac button lights up and the ac was recently charged but it doesnt blow cold. The heater works. I think it could also b the throw out bearing but not sure.
Old Nov 19, 2012 | 07:47 AM
B20DelSol's Avatar
Its no problem DelSol06...I was just pointing it out, but it is not a big deal to me. Check to see if the compressor clutch is engaging.
I am 99% sure it is your input shaft bearing inside the transmission. The throw out bearing will make noise WHEN you depress the clutch pedal. The Input shaft bearing, will make noise regardless UNTIL you depress the clutch pedal.
Old Nov 19, 2012 | 08:07 AM
DelSol06's Avatar
Okay ill check that out tomorrow. Do u know what tools and size sockets ill need? Thanks alot
Old Nov 19, 2012 | 08:44 AM
B20DelSol's Avatar
The input shaft bearing is only serviceable by removing the transmission and disassembling it.
Old Nov 19, 2012 | 04:23 PM
DelSol06's Avatar
Okay thanks but could it b my clutch n any way?
Old Nov 19, 2012 | 10:07 PM
B20DelSol's Avatar
It could, but the sound would be constant and get worse when you push the clutch pedal all the way down because the load from the pressure plate would be placed directly on the throwout bearing.
Like I said before, honda knows about this issue and made a TSB regarding it. The only way to fix it is to pull your tranny, take it apart, and replace it
Old Nov 20, 2012 | 08:12 AM
DelSol06's Avatar
Okay thanks.
Old Nov 20, 2012 | 11:45 AM
DelSol06's Avatar
Can the input shaft cause the tranny to leak? My car leaks a lil when the engine is on. But if its not turned on theres no leak im kinda lost about it. Thanks n advance
Old Nov 20, 2012 | 07:10 PM
DelSol06's Avatar
do you how much a isb costs? or where i can find a cheap one? and is it a quick fix if i took out the tranny?
Old Nov 20, 2012 | 09:01 PM
B20DelSol's Avatar
See where it is leaking from...it could be engine oil, coolant, tranny oil, power steering fluid. etc. Normally a bad seal or gasket somewhere will cause this, not a bad bearing.
The bearing itself is probably 10-20$ but its not something easy to do. You have to remove the tranny and then open it up, and remove everything inside just to get to it. I would recommend rebuilding the trans while you have it apart. A reputable rebuild kit is about $250 typically.
Old Nov 21, 2012 | 08:36 AM
DelSol06's Avatar
Yea i have a buddy that rebuilt his b18b1 tranny and his car runs like its new. So ill just replace the isb i hear theres a top and bottom. Any ideas where i can buy the isb. Autozone, o rileys, the dealers?
Old Nov 21, 2012 | 02:08 PM
B20DelSol's Avatar
These guys are supposed to be good.
http://shop.synchrotech-transmission...Series_c17.htm
Or see if your local auto parts store can special order a rebuild kit, although you can piece one together from the dealer.
I don't like Autozone or Oriley's...but if it is all you got, might as well go there.
delsolo95
May 30, 2014 11:24 AM
092eg6
Aug 23, 2010 08:30 AM
Azn Kenny
Oct 8, 2007 01:55 PM
P-DuBB
23
Aug 8, 2005 10:36 PM
b18c4door
Jul 9, 2003 05:09 AM
