swapping 95 f22b to 97 f22b???
Old Nov 21, 2012 | 12:53 PM
JsSIR's Avatar
Icon3 swapping 95 f22b to 97 f22b???
Ok the motor on my wifes 95 accord lx went and i been searching around the webz in my area and the only engine i can find was 97 f22b. Now my mecanic say that it wont work that the intake and exhaust manifolds are different. Now apart from one engine being obd1 and the other obd2 what do i need to do to make this swap work propperly?
*** I knpw most of you are guna say google is your friend and go search. I did try to search but i had no luck and i am short on time and need to get my wifes car back on the road asap. so please only helpful responses. thank you
Old Nov 21, 2012 | 07:24 PM
ce1 boy's Avatar
Default Re: swapping 95 f22b to 97 f22b???
well first off your mechanic is wrong BOTH manifolds are the same the only difference would be the f22b is a vtec whereas ur wifes car is non v,the engine will mount up just fine and run without any check engine codes if you use your intake manifold, your harness, your distrbutor and coil because the vtec engine has an internal coil and the non v is external,the only thing is you wont have vtec and where vtec should kick in lt will tach out of course you can make the vtec work a couple different ways but may get costly and tideous but if you need help with that i can help ya out there to...
Old Nov 21, 2012 | 08:34 PM
GhostAccord's Avatar
Is the 97 that you found an F22B1 VTEC or another F22B2 Non VTEC?
If it is a 96-97 F22B2 all you need to do is swap over your original OBD1 distributor and coil. The intake and exhaust ports on the head are the same and you can keep your original equipment.
Old Nov 21, 2012 | 09:16 PM
ce1 boy's Avatar
ghost is rite they did produce f22 b2 non v if thats the motor your getting plug nd play with your old dizzy nd harness
Old Nov 21, 2012 | 09:18 PM
ce1 boy's Avatar
crank pos sensor on block you can remove or leave unplugged if you use ur harness it dosent have plug for that cause its obd 1 nd computer isnt looking for it so no code and engine will still run fine...
Old Nov 22, 2012 | 05:04 AM
JsSIR's Avatar
The new motor is a non v also. So since both motors are non v motors its a striaght plug and play? With the exception of the crank sensor i should be able to plug all my original equipment with no modifications
Old Nov 22, 2012 | 05:08 AM
v4lu3s's Avatar
RTFM
it is called an engine replacement, not a swap or anything like that...
just put it in EXACTLY like the Factory service manual says to.
Old Nov 22, 2012 | 12:13 PM
Yes the computer (ECU) still looks for those 2 sensors TDC & CKP. And yes the ECU will throw a code if you do not hook them up.
The top dead center (TDC) and crank position sensor (CKP) on the OBD2 F22B2 are mounted on the oil pump housing. On your original OBD1 engine they are both found in the distributor along with the cylinder position sensor (CYP). Use your OBD1 distributor and you will have no issues with the crank sensor. You can remove the OBD2 sensors or just leave them there. Choice is yours!
Old Nov 22, 2012 | 03:18 PM
JsSIR's Avatar
Ok so as long as i use everything from the original motor i shouldnt have any issues. thanks GhostAccord.
Old Nov 22, 2012 | 03:22 PM
Yes sir..... convert the OBD2 engine to match your OBD1 chassis.
Curbstomp336
Nov 17, 2013 11:11 AM
90coupekami
Sep 23, 2012 11:22 AM
Bacondoggy
Jun 20, 2009 08:15 PM
SlaminRC17
Jan 8, 2007 03:15 AM
jiggaj97
Jan 28, 2004 11:04 AM
