How to put an engine on a stand....
Old Oct 18, 2002 | 04:41 PM
Blaze45's Avatar
Brrraaaap!
Default How to put an engine on a stand....
Well yeah it sounds stupid but I got the stand and the engine. It doesnt have a tranny so do i just use the l brackets and clamp em on? TIA
Blaze
Old Oct 18, 2002 | 05:39 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How to put an engine on a stand.... (sirk)
It wont bend the crank?
Old Oct 18, 2002 | 06:09 PM
Malgerus's Avatar
Default Re: How to put an engine on a stand.... (Blaze45)
Just assemble the hoist, lift the engine level to the stand, and use the tranny bolts to bolt the engine to the stand. be sure to evenly distribute the arms and make sure it is all level and that the engine won't fall when the hoist isn't holding it.
Old Oct 18, 2002 | 06:11 PM
gregv's Avatar
Honestly, I wouldn't advise bolting the engine stand to the crank (even if it could be done)
unless it was a Le Rhône rotary from a WW1 airplane. If your stand is like mine, you'll need
some extra-long bolts to bolt the mount attachment to the transmission side of the block.
Since this piece is usually seperate, you can bolt it on first; then lay the stand on its side and
slide the mount shaft into the stand. Then, you and a buddy lift it up the engine until the stand
sits in a normal position.
Or just rent an engine hoist for $20 bucks.
good luck
Old Oct 18, 2002 | 07:45 PM
Blaze45's Avatar
Brrraaaap!
Default Re: How to put an engine on a stand.... (gregv)
thanks
Blaze
bara6075
Oct 5, 2007 10:33 PM
aznguy0087
Jul 5, 2007 11:22 AM
madhatter07
Aug 2, 2003 06:05 PM
serious
Mar 12, 2003 03:27 PM
SamC
Aug 20, 2002 12:08 PM
