Want to Buy Want to Trade/Want to Buy
WTB: D16Y8 Auto to Manual Swap, Need Parts
Old Nov 20, 2012 | 10:50 PM
SohcShock00's Avatar
Default WTB: D16Y8 Auto to Manual Swap, Need Parts
Looking to do a manual swap on my 2000 automatic civic. Its a D16Y8, so i am looking for the complete swap if anyone has it, or just parts listed below. Im in South Jersey, but willing to travel north. If not, would appreciate parts shipped. Looking specifically for:
D16Y8 (EX) 5Spd Tranny
Tranny Mount/Bracket
Reverse Sensor/Speed Sensor
Clutch Master Cylinder
Clutch Lines
5 Spd Pedal Assembly
5spd OBD2b ECU for Vtec
PM or Bump for any items you have for sale. Thanks
Old Nov 21, 2012 | 04:07 AM
ReDemoN's Avatar
DixielandImports Please
Default Re: WTB: D16Y8 Auto to Manual Swap, Need Parts
I have a pedal assembly
60 Shipped
Old Nov 21, 2012 | 04:17 AM
forcfedcivic's Avatar
I have the front and top d trans mounts, pedal assy, hard lines, soft line, and clutch master and slave cylinder all from a 99 teg. They will work as I have used the lines etc from an eg into an ek for an auto to manual conversion..
Old Nov 21, 2012 | 02:23 PM
Fibercation's Avatar
I have ALL of it and the ecu $450 pickedup in central ohio also included is axles
Old Nov 21, 2012 | 08:58 PM
60 Shipped
Ill let you know man
Are you sure all of those parts will fit for my d-series?
Would you be willing to ship? Im from South Jersey
Old Nov 22, 2012 | 05:45 AM
Yes....I did an auto to manual conversion on an ek with the same parts. I do not have a tranny or linkage or the ecu. I have the flywheel, which will need turned and you'll still need a clutch as well....
Old Nov 22, 2012 | 06:49 AM
If I must I will shipbut its not gonna be cheap....pm me
Old Nov 22, 2012 | 07:49 PM
Mugen92Civic's Avatar
i have a whole 5 speed single cam swap axles ecu harness etc but non-vtec engine also has headers 400 picked up located in DE
Old Nov 26, 2012 | 07:04 PM
nihad's Avatar
text me at 319 883 5110 if you need anything I can get these parts i also have a y8 tranny that has a bad ISB in it ive been meaning to fix it..
Old Nov 27, 2012 | 10:18 AM
apexi_rsx's Avatar
i have a ex d series transmission for 250 it has both sensors. lighten flywheel for 50 or stock flywheel for 25. 50 for both axles. im located in DE.....PM me if intrested
Old Nov 27, 2012 | 05:38 PM
nihad's Avatar
D16Y8 (EX) 5Spd Tranny :I got a Y8 trans with a bad ISB
Reverse Sensor/Speed Sensor :I got this as well
Clutch Master Cylinder :I got this as well
Clutch Lines
5 Spd Pedal Assembly :I got these missing the clutch pedal got the brake/gas pedal in 5speed version not automatic 40$ shipped for these
Old Nov 30, 2012 | 12:13 AM
Has anyone done this swap before? Is it necessary to replace the axles?
Old Nov 30, 2012 | 05:17 AM
tamadrumr88's Avatar
Not necessary. Just did this swap in my EK. I have some parts left over too (clutch master and slave cylinder, EG hard lines, flywheel and bolts, pressure plate and bolts, clutch disc and more I'm sure). I have a 1999-2000 Y8 M/T engine harness too if you're looking to make it a cleaner installation without cutting up the old harness. I'm in eastern PA, about 15mins from Philipsburg, NJ.
Old Nov 30, 2012 | 03:17 PM
jdm inc's Avatar
i have ecu!
Old Dec 4, 2012 | 05:20 PM
ej1serge's Avatar
I have all this, pm me if interested ill let it go for cheap, willing to ship too.. Hit me up!
Old Dec 4, 2012 | 06:07 PM
h22accordcoupe's Avatar
I have ecu and sensors. $100 shipped
sohc it to me
Mar 31, 2015 07:10 AM
SohcShock00
Northeast (Sales)
Dec 29, 2012 05:57 PM
eh vtec sc
Dec 29, 2011 07:37 AM
deviant1
11
Apr 4, 2004 12:52 PM
DevinW
Apr 15, 2002 06:06 AM
