FS: LSVTEC (OEM P61/ARP) Short Block - Parts
Old Nov 20, 2012 | 08:58 PM
JerseySiPOS's Avatar
Default FS: LSVTEC (OEM P61/ARP) Short Block - Parts
**PICS ADDED BELOW**
Parts SOLD:
BARE BLOCK
CRANKSHAFT
I am selling a B18A1 (81x89) short block that I rebuilt in November 2010. It has been primarily used for hard road course, drag racing and daily driving. At the time of rebuild, it had new Honda OEM P61 (B17) 81mm pistons, Honda OEM piston rings, Clevite bearings, thrust washers, Honda OEM bottom end gasket kit, cylinder hone, micro-polished crankshaft and reconditioned OEM PR4 connecting rods with ARP rod bolts. The VTEC water pump and oil pumps were new from a previous build with low miles and are still in great working condition. On a side note, I am most likely keeping the water pipe and thermostat housing, but let me know if you are interested in the complete LSVTEC block or parts. A rebuild with an over-bore is recommended. Inquiries for other parts welcome. Please send me a private message.
LSVTEC Short Block (Before Part-Out) Pics
LSVTEC/B20VTEC Honda PR4 Rods + 81MM P61 Pistons w/ ARP Bolts - $150
Lower Timing Belt Cover - $25
B18/B20 Timing Belt - $30
Timing Tensioner - $20
Crank Gear & Washers - $20
Oil Pump - $50
Water Pump - $35
Oil Pan - $50
LSVTEC/B20VTEC/B16A Oil Strainer - $25
Windage Tray - $30
Alternator Brackets - $50
Water Pipe - $TBA
Thermostat Housing / Cover - $TBA
Oil Pressure Sender/Sensor - $20
- i.
Old Nov 26, 2012 | 10:56 PM
Default Re: FS: LSVTEC (OEM P61/ARP) Short Block - Parts
clean start for serious builders.
Old Nov 30, 2012 | 04:09 AM
Bare Block + Crankshaft PENDING
Old Dec 3, 2012 | 06:28 PM
Private message me for good B-series VTEC parts.
Old Dec 9, 2012 | 09:28 AM
Don't sleep.
Old Dec 17, 2012 | 03:03 PM
colombianchulo07's Avatar
Text me interested in the block 551-200-4769
Old Jan 3, 2013 | 03:07 PM
Bare block and crankshaft are sold. Remaining list is at the top.
Old Jan 29, 2013 | 03:26 PM
Honda OEM.
Old Apr 14, 2013 | 06:22 PM
ready for fast pick up.
esco115
Feb 18, 2014 05:14 PM
JerseySiPOS
Apr 14, 2013 06:20 PM
TrackSpeedRacing
Northern California (Sales)
Dec 23, 2008 02:51 PM
4drsedaneg
May 28, 2005 05:56 AM
b16vtecsol
Nov 18, 2003 01:42 PM
