Crover1 vs. K20A (JDM) in K20A2??
i would upgrade the cams in my K20A2 engine; i cannot find used JDM DC5R cams and so looked and found the Crower1 which i can use with stock valvetrain.
is that correct, can i use it with stock A2 valvetrain? max. RPM?
i checked today the valve spring item number from JDM K20A and my K20A2 (facelift year 2005) and its the same.
does anyone use that Crower1 and make that the same or a little better performance as the JDM cams?
http://www.crower.com/camshafts/acur...pair-7229.html
my setup:
RBC IM
Toda header with 200cell cat
OEM JDM EP3 exhaust system
Carbon Airbox
K-Pro
its an daily drive car only!
my setup:
RBC IM
Carbon Airbox
K-Pro
Why not Drag Cartel or Kelford DICs (Drop in Cams)? Are they available to you in Austria? Try 8thgencivic.com, they have a lot of good information about different K series cams.
shomershavis
10
Jan 13, 2005 08:18 AM
dominate9
Jan 13, 2005 04:08 AM
