Civic aerodeck 1.5 1999 OBD2?
I have a station wagon 1999 Aerodeck 1.5 vtec-e EU modell who i cant find the obd2 connector on..
Have been told by some that is could be on the passenger side??! but cant find it there either, and canīt see it either on the driverside..
Could someone point me out with pictures maybe where it is..
Regards Micki
Regards Micki
It should be on the drivers side by where your left foot would be. Get on your back and look around. If it's not there it's gotta be somewhere under the dash. Should be easy to find if you know what you're looking for. More than likely on the driver side.
Got some pictures of your beauty? I'd love to see.
You (should) have the D15Z8 motor, which is paired with the P9L ECU. As far as I can tell, that ECU is kind of a bastard child.
If you could look at the block stamp, as well as the ECU and confirm that for us, that would be great. The block stamp will be on the block, just behind the radiator, near where the transmission mates to the block. The ECU sticker will be on the ECU itself, which should be behind the passenger side kick panel, under the glove box.
sumoneEK
10
Sep 3, 2010 06:53 AM
ekfighter
Jul 17, 2004 09:42 PM
