Need help with IAT and ECT compensation S300
Old Nov 19, 2012 | 04:15 PM
bvillarreal's Avatar
Icon2 Need help with IAT and ECT compensation S300
My current tune was tuned when IAT was 80* now it is around 55* and my car idles and cruises at 10.5 and cruises at around 12.5 for a good 15 minutes until it is pretty warmed up and I was wondering if somebody could help me with the compensations here. Ive read that the stock compensations work well, but in my case it isnt. Any help is appreciated.
Old Nov 19, 2012 | 05:17 PM
Default Re: Need help with IAT and ECT compensation S300
anybody? these are the stock values, wondering if anybody could point me in the direction on where to put them?
Old Nov 19, 2012 | 06:38 PM
Muckman's Avatar
Moderator in Chief
Just reduce the values in the IAT temp cells 67* and below.
Old Nov 19, 2012 | 08:29 PM
Ect only or IAT also?
Old Nov 20, 2012 | 05:30 AM
Muckman's Avatar
Moderator in Chief
Start with just the 3 IAT load rows. I would reduce those values significantly.
Old Nov 20, 2012 | 07:08 AM
Thanks for the input. Every bit helps. Now sorry if this sounds stupid, but say I'm trying to decrease the 60* portion, do you change the box nearest to 60 or do you manually change the number in the temp box and then change the %.. Because it jumps from 67* to 123* on the table above lol
Old Nov 20, 2012 | 07:15 AM
Muckman's Avatar
Moderator in Chief
You can grab the value below the 67* column. Cut em in by 1/3 to 1/2.
Old Nov 20, 2012 | 08:46 AM
Thanks man, will try later
Old Nov 20, 2012 | 02:25 PM
did what you said, fixed 90% thanks man!
Old Nov 21, 2012 | 05:25 AM
xenocron's Avatar
Stock values usually work pretty well...if your part throttle was tuned to 14.7 and now its 12.5 or richer, you have some other issue going on.
Old Nov 21, 2012 | 05:50 AM
mtber's Avatar
Old Nov 21, 2012 | 10:26 AM
Yeah I read that the stock values usually do work well. But then again I read that if you have bigger injectors it'll throw it off in the changing of the weather. I didn't mean to put 12.5 I meant 11.5 until it's All the way warmed up. Just was wondering if there's anyway to get the fuel the same 24/7. Anyways I'm not messing with it at all anymore, gotta save up for a real tuner.
Old Nov 21, 2012 | 02:10 PM
xenocron's Avatar
While the car warms up, you want it to be richer...thats what you have a coolant temp sensor for...it is there to add extra fuel while the motor is cold since the atomization isnt as good, and the motor will need extra fuel to run properly.
If it runs at 14.7 cruising once fully warm...thats what it is supposed to do!
Old Nov 22, 2012 | 07:03 PM
VegasInvasion's Avatar
I'm Huge In Japan
good option.
spooty
Sep 22, 2008 07:46 PM
HondataDemon
Audio / Security / Video
Feb 24, 2004 06:08 PM
