What's the deal
Old Nov 19, 2012 | 02:53 PM
cullylude05's Avatar
Default What's the deal
R the SH cv axles the same as the base axles or not? Anyone know for 100 percent? Ive always read the drivers side was different and if I remember correctly Honda dealership has two different part numbers, which I'll call the parts department tomorrow to double check, And I'm almost sure NAPA had two different part numbers too but I know I've read over and over the left is different and a few times I've read the right side is. I have a SH drivers side sitting here and matching it up to a aftermarket cv shaft that's labeled for both base and SH appears to be very close to the same if not the same? What's the deal? Anyone
Old Nov 19, 2012 | 04:48 PM
snobordboy's Avatar
Moderator
Default Re: What's the deal
They are different, not by alot, but enough.
Old Nov 19, 2012 | 06:04 PM
Thanks just the left correct and right is ok?
Old Nov 20, 2012 | 07:11 AM
snobordboy's Avatar
Moderator
From what I have seen, the Pass. side should be the same, no ATTS box to worry about on that side.
Draiga1988
Mar 8, 2012 06:59 PM
zic
Nov 23, 2007 07:15 AM
6E LUDE
Nov 5, 2006 04:03 PM
DCbb6
Mar 16, 2006 12:37 PM
GruvyTune
Sep 28, 2002 06:17 AM
