Honda civic idle is to high help
Old Nov 19, 2012 | 08:56 AM
Hondakid28's Avatar
Default Honda civic idle is to high help
Hi everyone I just recently did a engine swap on my Honda civic ex 1997 D16Y8 but I'm getting the idle to high.any help please I would really appreciated it.
Old Nov 19, 2012 | 09:40 AM
jbpnoman's Avatar
Default Re: Honda civic idle is to high help
Check for vacuum leaks, make sure all of your lines are hooked up correctly, and follow the FSM procedure for adjusting idle. Is the CEL on? Does it work?
Old Nov 19, 2012 | 10:01 AM
Cheefer_EX's Avatar
Does your intake manifold match the long block? (D16y8=D16y8) or is it like a mini-me?
-Vacuum leak
-need to bleed air in coolant
-IACV or FITV is not functioning properly
-TPS is toast (doubtful)
Do the typical test with carb cleaner sprayed onto the gasket at the throttle body, intake gasket, and vacuum lines. If it bogs then there is where to start with your leak. Also, a smoke machine is a good test but you would need to know a mechanic most likely.
Old Nov 19, 2012 | 11:33 AM
Hondakid28's Avatar
Yeah it's a complete swap not mini swap. I will check the 4 things you guys told me and I will post back and see if they were the problem. Thank you guys for the help..
SOHC_civic_si
16
Dec 29, 2010 02:25 PM
Tanner911
Mar 2, 2010 06:55 PM
DumaDA
Feb 10, 2010 11:57 AM
Mr.DXt
Jan 13, 2010 08:27 AM
Hnda_Crx_Man
Apr 1, 2002 11:28 PM
