FS: B18 Series Type R Crank
Old Nov 19, 2012 | 08:23 AM
williamZ's Avatar
Default FS: B18 Series Type R Crank
I am selling a Type-R crank that I was going to use in a build but I sold the car. Great condition!
$400
If you have a B18C and are building it from the ground up for road racing or a street motor, this is the best crankshaft to have. The Integra Type-R crankshaft is fully counter-weighted. This equates to less harmonics at high-rpm and more horsepower, as the engine spins more free. The stroke on this crankshaft is the same as a GSR at 87.2mm. You can combine this with a standard 81mm bore, or you can go all the way up to 82mm on stock sleeves. If you install aftermarket ductile iron sleeves, you can achieve bore sizes from 84mm all the way to 86mm. When utilizing bore sizes from 84mm and up, you are in the 2.0 liter, plus territory. Using this stroke allows you to maintain a better rod to stroke ratio and the high revs that the engine expierences will not produce as much crank flex as a GSR or B20 crankshaft. Combinations with this crankshaft will make for a more reliable setup that can be driven everyday and taken to the track on the weekends.
Located in WI.
Old Nov 20, 2012 | 11:05 PM
__erik__'s Avatar
10 Year Member
Default Re: FS: B18 Series Type R Crank
thats a lot of doll hairs for just a crank.
Old Nov 24, 2012 | 05:20 PM
williamZ's Avatar
Ok. $300.
Old Nov 24, 2012 | 08:38 PM
trbo95's Avatar
Where in WI are you located? I may be interested.
Old Nov 24, 2012 | 10:46 PM
williamZ's Avatar
40 min NW of Milwaukee.
Old Dec 8, 2012 | 03:57 PM
williamZ's Avatar
SOLD for $356..
DA9tothewheel
Engine Machining & Assembly
Dec 11, 2015 07:00 AM
b18cvtec
Jan 25, 2011 05:33 AM
HyperFlow
Aug 4, 2010 08:55 AM
Dropspeed
Oct 18, 2003 07:10 AM
Nice_Dc2r
Mar 30, 2003 07:31 PM
