RHD EK Sedan door panels to LHD car?
can i use rhd door panels in a lhd sedan? i know with the 2dr i can but im looking at the size of the switches with the sedan and the panel.or do i need to get LHD panels?
this is a rhd switch....
and the lhd switch......
Do you really want the the passenger to control the locks and windows? lol
According to: 94EG8, you just need USDM switches
The door panels are the same, door harnesses you can swap from one side to the other. You need USDM switches though unless you don't mind not being able to roll down the window from the driver's side. Floor harness you couldn't really use, you could just take the power window wiring out flip it over and integrate it into your floor harness. Regulators can be used.
lol ^^ i was looking at the switch tho.im wondering how i can put a 4 button switch to where a 1 button was and vice versa.wont there he a hole showing thru the panel ?
...have anyone used RHD sedan panels in LHD car?
I suspect the size of the hole for the driver's USDM door handle with integrated lock switch into the bezel is different from the JDM passenger side. So, what I'm saying is the hole for the interior door handle will be too small and you'll have to trim. Not an insurmountable problem but just something to be prepared for.
Rude Awakening
Sep 15, 2015 03:37 PM
.hawaii
Oct 28, 2010 01:16 PM
preludexl
16
Jun 15, 2008 03:55 PM
