Honda S2000 Honda S2000
17 inch wheel confusion
Old Nov 18, 2012 | 05:24 PM
2003stock's Avatar
Default 17 inch wheel confusion
Hello.
I want to buy new wheels for 2003 S2000. The car is stock suspension and stock everything else. I just want 17 inch, to go a little bigger than the 16 inch factory wheels.
I am confused what offset I should be getting with 17 inch wheels.
Most of the wheels at TireRack have a warning saying... "offset of +45 is aggressive and may require fender modification".... I definitely don't want that.
What should I be looking for?
What range of offset is proper for my car?
I searched the forum and found proper offsets for 18 inch, but not for 17.
Thank you for any help Honda Tech peoples. :-)
Old Nov 19, 2012 | 07:03 AM
Black S2K's Avatar
Default Re: 17 inch wheel confusion
How low r u? And how wide of a wheel do u want to run?
Old Nov 19, 2012 | 09:23 AM
BLANCOh22a4's Avatar
do you not read dipshit? he says hes on stock suspension/stock height. OP if your is at stock height you could run any offset, but then again it will be 4x4 status. If you are moderately dropped like me at about an inch or so, i run 17x8+38 F 17x9+40 R which is a more common FUNCTIONAL setup. With this my rears required a small roll which is not a hard process if you have the rolling tool. Offset wise, stay above 40 for a non crazy offset.
Old Nov 19, 2012 | 10:09 AM
Black S2K's Avatar
woo there sally i read it on my ipod while was in class forgive me for missing some of it
Old Nov 20, 2012 | 07:30 AM
JulieU's Avatar
Don't your wheels/tires stick out from the fenders though or do you have them cambered in?
Regardless OP, if you plan on sticking with stock suspension and alignment specs, I don't think you'd want the offset to be much less than +54 front and +60 rear.
Also, you may find this helpful: Wheel Fitment Guide
Old Nov 20, 2012 | 04:19 PM
H22A_CD5's Avatar
^^^ Yep.
17x8.5 +40 here. takes about -3 degrees of camber with a moderate roll and bumper tab relocation in the rear to tuck them with 255s and little to no fender gap. Still rubs once in a while.
Old Nov 20, 2012 | 10:10 PM
Brice.Hayden's Avatar
I ran 17x8 + 35 with no fender modifications. Does not rub.
Old Nov 24, 2012 | 01:46 PM
unethikl's Avatar
IMHO, keep the oem 16s. You're at stock height.. only oem look good on stock height.
Old Nov 28, 2012 | 09:14 PM
romeo2's Avatar
Originally Posted by romeo2
H22A_CD5, just on the offset difference alone you are starting 1" wider than the stock wheels for AP2 which have an offset of 65mm. I can see the need for rolling fenders etc wth a 255 tire. I am in Phoenix with my S2000 for the winter and my rear fender liner system installed and wonder if we could meet up sometime to compare notes as I am always looking for wheels that will allow me to install a BBK, as the OEM wheels will not allow me to do that. Also trying to collect info for the limitations of my rear liner system to answer questions from potential purchasers and I need to know the limitations of these variables to be able to do that. You could PM me at romeo2r2@gmail.com.
Old Nov 29, 2012 | 04:02 PM
HondaKyle's Avatar
17 x 9.5 +35 with a 255 you will need camber to fit it in.
rob_a
Nov 16, 2008 04:14 PM
ZXRider
May 1, 2007 01:25 PM
Dr. Jay
Mar 28, 2005 04:47 PM
Teh_Oven
Jan 31, 2005 10:13 PM
RTW DC2R
Sep 8, 2002 04:07 AM
