aftermarket trans fluid
Old Nov 18, 2012 | 04:07 PM
hlinar's Avatar
Default what to use if Honda atf isn't available?
2000 accord 4 cyl 199k. It's Sunday. Over 1 qt low. My daughter's
Would anyone chance anything else?
Old Nov 18, 2012 | 04:26 PM
jdowen2's Avatar
Default Re: aftermarket trans fluid
I did a complete flush using Redline ATF.
Old Nov 19, 2012 | 02:31 PM
Lost Again's Avatar
Honda dealer, brick and mortar or online.....Carquest Auto
Old Nov 19, 2012 | 03:01 PM
hlinar's Avatar
That's pretty much what I gathered. today, Monday I bought 2 qts at the dealer. Topped the trans off, and stuck the fresh quart in the trunk Explained to her ONLY Honda trans fluid.
Probably in one ear and out the other,(21 yrs old) but since I do the work on it, I have backup here at my house.
thanks
Old Nov 19, 2012 | 03:34 PM
Lost Again's Avatar
My pleasure.....online you can find the fluid for ~$5 to ~$6 in case lots. In a pinch carquest has it for $7.99 qt. I have enough of them with auto trans that I buy it in case qtys.
And yes, I had a boy at that age once ....got another two years from that age as well so I know what you mean.
Old Nov 19, 2012 | 03:41 PM
hlinar's Avatar
No carquest around Little Rock, but I only(?) paid 7.77 How often should I do the 3 qt change?
Old Nov 19, 2012 | 03:50 PM
Lost Again's Avatar
Well, you aren't going to like what I have to say.....the 98-02 Accord Auto trans is.....well made of glass IMO. If you do city driving, every 10K to 15K. In this gen there is something in the valve body, or something like that, that will stick causing the fluid not to flow thru the trans cooler below ~1,200 rpms. There are "kits" to repair/correct this issue but that usually comes with a trans rebuild.
Not trying to scare you, just giving the facts. Madmike posted this a while back: http://www.sonnax.com/system/pdfs/35...pdf?1320330979
It has to be the best info I have found/read to date on the issues with the 6th gen Accord/Ody auto trans issues.
Some have no issues at all, others do....so it is hit or miss on them going. The earlier gens.....can't kill those. The newer ones have a few issues but nothing like the 98-02.
Old Nov 19, 2012 | 05:54 PM
hlinar's Avatar
Yep, thats what I've been reading.P.O.S. for a transmission.
It's running okay now and was before I replaced the radiator ( split seam) and 3 +qt trans change 2 weeks ago. (knock wood) I just want to make sure it stays problem free.
The article scares the %^&* out of me and I juuuuust want to keep things nice.
hokietiger
Feb 8, 2015 12:52 PM
lovedam
Sep 9, 2011 04:21 PM
mozee82
25
May 19, 2010 05:30 AM
mrgenuine
Honda Civic (2006 - 2015)
Jan 16, 2007 05:15 PM
97crv dude
Feb 20, 2005 11:41 PM
