defroster wont work, intermittent wipers wont work
Old Nov 18, 2012 | 08:28 AM
ravenwoodranch's Avatar
Default defroster wont work, intermittent wipers wont work
97 CD6 Accord 4dr 5spd with f22b1. so as title says neither are working, relay seems ok, could the switch be going out in either
Old Nov 18, 2012 | 09:08 AM
Lost Again's Avatar
Default Re: defroster wont work, intermittent wipers wont work
Front or rear defroster?
I'd check the interm relay for the wipers. Test the relay and then inputs.
Old Nov 18, 2012 | 10:25 AM
ok thanks, and its the rear defroster for the window
Old Nov 18, 2012 | 12:18 PM
pcfast's Avatar
I'd like to hear answers about the rear defroster as well, since mine is not working. Mine actually has water condensation on the window, so I hope it's not the heater core!
Old Nov 18, 2012 | 12:31 PM
condensation inside the car usually represents moisture inside the car, would check leaks around the doors and see if the floors are wet
Old Nov 18, 2012 | 07:32 PM
pcfast's Avatar
Don't think the floors are wet, but I will check!
Old Nov 19, 2012 | 02:41 PM
Lost Again's Avatar
For the rear, you'll need to be sure there is not a break in the "grid". It also has a relay.......I'm assuming you checked all of the fuses, correct?
Old Nov 19, 2012 | 05:14 PM
yes, didnt look for a break but didnt think anything could break it unless some one was back there
Old Nov 20, 2012 | 06:50 PM
Lost Again's Avatar
Don't know the history here...was it working and then one day stopped......or was working and "I cleaned the window" and it stopped....or has not worked since I've owned the car for "x".
dtward63
Jul 3, 2015 04:13 AM
supermotothud
Dec 13, 2008 07:25 PM
b20acura
Jun 25, 2006 12:45 PM
harwood39
Oct 24, 2004 06:37 PM
Unjockable
10
Jan 1, 2004 09:44 PM
