shimmed valve springs for better rpm?
Old Nov 17, 2012 | 05:53 PM
EG-SIXV-TEC's Avatar
Post shimmed valve springs for better rpm?
i got a resurfaced sohc v cylinder head. the valves springs been reused and placed with washer looking shims under the valve springs. do i bennifit from anything. when racing and going turbo setup.
Old Nov 18, 2012 | 02:00 AM
jbpnoman's Avatar
Default Re: shimmed valve springs for better rpm?
A) They're called valve spring retainers
B) No
C) stop street racing
Old Nov 18, 2012 | 05:45 AM
4piston's Avatar
Springs are often shimmed up to get more seat pressure. It will decrease your room to coil bind. Just have a local cylinder head shop check the spring pressure at that installed height and tell you what it is. Then come back with that info and someone will be able to tell you if you have enough spring for what you are trying to do. List your cam size, engine rpm, and boost pressure also.
Old Nov 18, 2012 | 07:32 PM
Post Re: shimmed valve springs for better rpm?
idk what the spring pressure etc, but its been shimmed and the camshaft is the stock d16z6 cam shaft etc. the engine rpm i am going or shooting for is the stock d16z6 ecu redline or maybe more?
im going to boost the motor @ 8psi max. i told him about it.
what rpm i shoud saftely rev up to fine with this setup idk what the shim specs etc. can i bennifit anything if i rev it alittle higher??
89efhatchy
Mar 12, 2014 08:49 AM
oresama
Dec 2, 2012 02:27 PM
xjdmjunkiex
Jul 15, 2012 10:45 AM
kaymoto
11
Jan 25, 2012 08:35 PM
TRuST
Sep 2, 2004 03:29 PM
