Rebuilt Calipers, still sticking..
Old Nov 17, 2012 | 04:57 PM
BIGef's Avatar
Default Rebuilt Calipers, still sticking..
Okay My old calipers on my sedan were sticking real bad.
Tried bleeding the brakes and i notice front passenger , hardly fluid comes out.
So i just bought got myself a donor hatch and got the calipers there and rebuilt them.
I made sure i lubed them and clean em good.
Put it on Bled the brakes front passenger still doing the same when bleeding.
Barely fluid coming out have to be stepping on it.
So Test drove it there still sticking. -_-
Could this be brake lines clogged? stretched?
Old Nov 18, 2012 | 07:33 AM
bk7794's Avatar
Default Re: Rebuilt Calipers, still sticking..
maybe its the rubber brake lines going to the caliper. I had that happen twice on two different cars, a ford and a chrysler. I think the rubber inside just collapses. Give that a try, just be careful when you loosen it from the metal lines. Make sure you spray penetrating oil on the connector so the connector and the line does not twist and kink. That almost happened to me.
Just replace them, they should be like 25 bucks or so at an auto store.
Old Nov 19, 2012 | 05:38 AM
BIGef's Avatar
Alright ill try and replace em.
Anyone else?
Old Nov 19, 2012 | 08:35 AM
Tyson's Avatar
Replace rubber hoses. Stock is fine, they're just old.
Old Nov 19, 2012 | 11:28 PM
BIGef's Avatar
thanks
KDee Underwood
Honda Civic (2001 - 2005)
May 8, 2016 10:43 AM
curtie94
Mar 19, 2012 03:27 AM
pair8hd
Suspension & Brakes
Sep 3, 2008 07:35 PM
oufyaba
Acura TL, RL & ZDX
Oct 21, 2004 10:35 AM
rob1208lv
Mar 15, 2002 03:02 AM
