Do I have transmission problems?
Old Nov 17, 2012 | 03:06 PM
Hexar's Avatar
Default Do I have transmission problems?
Hi Guys,
A friend and I are working on a CRX swap. The car is a 89 CRX with D16A6 with manual trans, we are putting in a D16Z6 from a 92-95 Civic, but we use the old trans from the D16A6 motor, with new a clutch and pressure plate.
Currently, the swap is done, and we found out maybe we have problems with the transmission, when we try to put back the axles and try to tighten the axle nuts.
The observations are:
1. If we turn the crank, the axles will turn, and if we switch into different gear, the axle turns at different rate as the crank is turned, and if we put it into reverse, the axle turns in opposite direction, so it seems good, but we can easily stop the axle from turning by hands.
2. if we turn the axle by hand, the pressure plate does not turn.
so when we try to tighten the big axle nut, the axle just keep turning. We tried to put it into gear (1 to 5 and reverse), hoping the engine will stop the axle from turning, but it does not.
So, is the transmission bad? Or maybe we should put the car on the ground and then tighten the axle nut?
Or is it normal? I mean, do we have to stop the other axle before this axle can turn the engine?
Thanks!
Old Nov 17, 2012 | 06:31 PM
~sp33~'s Avatar
EFB055
Default Re: Do I have transmission problems?
That's all normal for a car with an open diff (non lsd transmission).
Old Nov 19, 2012 | 01:03 AM
crxdxmusbslo's Avatar
Have a friend hold down the brakes. PUmp them up real tight and have them hold them, then tighten with a breaker bar. Make sure the c clip seated first though.
angrysmileyface
Oct 11, 2015 03:57 PM
ralphieg
Oct 2, 2012 06:36 PM
98GreenTegGSR
Jan 3, 2009 06:21 AM
technine
11
Dec 20, 2002 08:42 PM
