why is my type r miss firing?
Old Oct 18, 2002 | 02:03 PM
andrewasf77's Avatar
Default why is my type r miss firing?
Hello all of you type r enthusiasts, ive got a question. a while back i bent most of the valves on my 97 type r. i had them replaced and now the engine is miss firing at around 7100 rpm. im really not sure what the problem is. ive taken it to a couple of shops and they havent said much. one guy adjusted the timing and the ignition and replaced the plugs, that didnt help. any of you out there with any thoughts, or someone who has had this problem, please give me some guidance. thanks alot.
Old Oct 18, 2002 | 02:06 PM
uNF$@#!'s Avatar
Default Re: why is my type r miss firing? (andrewasf77)
probably a **** job done on the repair work
Old Oct 18, 2002 | 02:16 PM
tecnic1's Avatar
mine did that a while back...
4 huge cracks in the distributor cap and a torched contact.
I'm sure your shop checked that though.
Old Oct 18, 2002 | 02:21 PM
JSPEEDNC's Avatar
Default Re: why is my type r miss firing? (tecnic1)
Have you done a leak down? Which valves did you bend?
Old Oct 18, 2002 | 02:27 PM
Default Re: why is my type r miss firing? (JSPEEDNC)
honestly, im not sure if a leak down was done, i bent 14 of the valves
Old Oct 18, 2002 | 03:10 PM
Default Re: why is my type r miss firing? (Soup ****)
any other possibilities??
Old Oct 18, 2002 | 05:02 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Bad distributor coils. Happened on mine. The car just wouldn't pull past 7k. I had a friends freaking 1.8T Passat that runs a 14.6 put bus lengths on me. I'd hold him off till 7k then after that he would put 3 cars on me before the next gear.
Old Oct 18, 2002 | 05:12 PM
Default Re: why is my type r miss firing? (Active (ActiveAero))
ok, thanks, i will have the shop check that out, i was thinking thats what it was, i talk to another guy on here that said he bent some valves in his b16, and his was miss firing and he replaced his dizzy, i thought it might have just been coincidence, but i guess not.
Old Oct 18, 2002 | 07:01 PM
JPP's Avatar
JPP
are you getting an "engine" light or are you just assuming it is a misfire ?
Misfire can be caused by a number of falty things such as:
-distributor coil
-distributor cap
-igntion wires
-spark plugs
-injectors
-fuel pressure regulator
-bad gasoline
-low compression
For misfire at high rpm the Helm manual suggest to check the following systems in this order:
-Fuel pressure
-VETC system
-Distributor / ignition wires
-ICM (sorry didn't have time to check what that system is)
-Valve clearance
Also I am not sure that bending valves would have anything to do with a falty distributor. Probably a coincidence if this is the problem.
Good luck
Old Oct 18, 2002 | 09:02 PM
Buckshot's Avatar
Default Re: why is my type r miss firing? (JPP)
maybe it has somethin to do with your O2 sensor...
mine was cuttin out once and it was b/c of the 02 senor..but mine did it at a lower rpm
Old Oct 19, 2002 | 07:49 PM
Default Re: why is my type r miss firing? (Buckshot)
anybody else got any thoughts on this problem i have??
Old Oct 20, 2002 | 08:43 AM
no engie light comes on, i can just feel the car missing when i get the rpms to 7k, it almost feel like its hitting the rev limiter.
Old Oct 20, 2002 | 06:03 PM
im still not sure what the problem, i would apprecite any other input about this situation. thanks
Old Oct 20, 2002 | 06:14 PM
ITR21's Avatar
funny i have the same problem and almost the same situation
Old Oct 20, 2002 | 06:28 PM
Buckshot's Avatar
Default Re: why is my type r miss firing? (ITR21)
O2 sensor man..you would be surprised how much control it has on ur car...
Old Oct 31, 2002 | 08:05 AM
thanks for all the help guys, when i get the problem solved ill post the problem and the solution
Old Oct 31, 2002 | 08:16 AM
Bbasso's Avatar
Has the ECU been messed with? maybe someone swapped it out for a civic ex ecu.
DOH! that would suck.
gummybear
Mar 23, 2008 12:08 PM
Kyle244R948
Nov 7, 2004 08:36 AM
tcb18c5crx
May 18, 2003 06:20 PM
andrewasf77
11
Oct 19, 2002 09:15 PM
andrewasf77
Oct 19, 2002 07:52 PM
