91 accord intermittently starts with starter fluid
Old Nov 17, 2012 | 07:01 AM
MrMagic81's Avatar
Default 91 accord intermittently starts with starter fluid
It intermittently starts and when it does it runs rough for a few seconds then it even out just fine. When it doesnt start, i apply starter fluid in the intake and it starts right up. New main relay, new battey, clean tight terminals, new distributor cap and rotor button its getting fuel pressure and the engine coolant temp sensor is fine ohm check is good. When attempting to start i get R, R, R, until starter fluid is applied. IM STUMPED!
Old Nov 19, 2012 | 09:21 AM
Jeff96-993's Avatar
Default Re: 91 accord intermittently starts with starter fluid
Had the same problem. Fixed it by replacing the o-ring gasket under the distributor cap.
You'll have to call around to find one. There was only one available in the entire city of Cincinnati when I needed it. Good luck!
thasickness
Nov 30, 2014 02:23 AM
MrMagic81
Nov 19, 2012 03:22 PM
troyflake
Aug 4, 2006 09:29 PM
fst fox
Nov 17, 2004 07:02 PM
2muchPSI
Dec 22, 2003 06:58 PM
