high idle at cold start
Old Nov 16, 2012 | 06:03 PM
anthonybenfield's Avatar
Default high idle at cold start
i just bought a 96 integra that has a gsr swap. car runs great when warm but at a cold start it revs to 2500-3000 rpms and slowly comes back down. this is the first honda i have ever had. any ideas why this would be happening. thanks
Old Nov 16, 2012 | 07:03 PM
lsturbo*'s Avatar
Default Re: high idle at cold start
Hondas, like most other cars, idle higher when cold to bring the engine up to operating temperature faster to reduce emissions. Basically, when you start a cold engine, your emissions are bad, cat is cold, and you can't burn off excess fuel efficiently. Now with that being said, 3000 rpms is a little high, so maybe your IACV is a little dirty. But overall I would say it normal. What ambient temp is this happening at?
Old Nov 17, 2012 | 06:02 AM
stocker2shocker91's Avatar
I requested a short story for a title.
^^^^this, you have nothing to worry about
Old Nov 17, 2012 | 12:01 PM
thanks guys. what is the IACV and how do you get it clean
Old Nov 17, 2012 | 12:26 PM
fcm's Avatar
fcm
Old Fart
As mentioned 3000 RPM is high, there are more then a few DIY IACV cleanings on here and Google, search an ye shall find. 94
Old Nov 17, 2012 | 03:18 PM
Hectos's Avatar
It could be your Fast Idle Thermo Valv. i have a b20b block with a b-18 head and had same issues cleaned the fitv and it ran better lower idle at start also
check this thread out wildoutwhitegsr did a great write up on it:
*** How-To*** Clean Your FITV aka Fast Idle Thermo Valve
Good luck (high idle during dry start isnt good in the long run)
DA's for life
Old Nov 17, 2012 | 03:20 PM
Hectos's Avatar
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/ link to the thread for FITV
DA's for life
Old Nov 17, 2012 | 04:17 PM
el crapitan's Avatar
an easy way to diagnose would be to cover the iacv port in the throttlebody bore with tape. start the car. if the idle is at a normal speed cold, problem is iac related. if not, it's all fitv. iac port is the upper of the 2 ports inside the throttlebody. if you only have one port, the car does not utilize a fitv and the problem could be the ect sensor or iacv.
another possibility is ignition timing. check timing with a light.
Old Nov 19, 2012 | 11:12 AM
wunfstgsr's Avatar
Loved
Community Favorite
**** my ITR revs to 1500 rpm lol on cold starts. But i have a outlaw engineering spacer kit that puts a thermal spacer between the iacv. But it idles down to 900 quickly or i just start driving and the motor warms up better. But i always had a high idle on cold starts with most all my b series so id say its not that uncommon. Might need to be cleaned and put a new gasket.
Old Nov 19, 2012 | 11:20 AM
fcm's Avatar
fcm
Old Fart
High yes, but 3000 RPM is too high. 94
aeon117
Mar 5, 2014 09:21 AM
95Sedan
Oct 11, 2013 03:29 PM
LShatchie
Apr 3, 2005 04:40 PM
RR98DX
May 9, 2002 04:46 PM
iwhichisme
Mar 15, 2002 04:31 PM
