All Motor B20 Vtec BROKEN!! Please help
Old Nov 16, 2012 | 02:05 AM
GreenbeaN069's Avatar
Default All Motor B20 Vtec BROKEN!! Please help
Good day to all members. i am new to the honda tech forum and this is my first post, unfortunately its not a happy one.
Il get straight to the point.
I not too long ago built a B20 Vtec in my civic. With just Over 20 000km's
on the engine the motor broke! i am left speachless. The motor was built by
a reputable tuner (JDM Tuning) and all parts were original and new.
Here is the parts i used in the build:
B20 block (honed)
Standard Crank
Eagle Rods
Wiseco Pistons
Acl Race bearings
B16 Vtec head
OEM Valves
ARP Head bolts
B16b cams
BC dual valve springs and retainers
Honda gaskets
Gates Blue Belt
Castrol Magnatec oil.
What happened...While on the highway i was flatout in third gear and
took it to around 8800rpm and when i changed to 4th gear...snap!
upon opening the motor, piston number 3 had broken.
the piston had broken off the rod with the pinnion still in the rod.
how can a forged piston break so easily?
Please help me out guys i have no idea what to do...
any info would be greatly appreciated.
Old Nov 16, 2012 | 02:09 AM
Default Re: All Motor B20 Vtec BROKEN!! Please help
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Old Nov 16, 2012 | 07:20 AM
roycivic92's Avatar
Sucks.... but new parts fail also....
Old Nov 16, 2012 | 08:52 AM
EsotericImage's Avatar
Retired Moderator
im still cringing just lookin at it
Old Nov 16, 2012 | 09:12 AM
C2K_TB_TEC's Avatar
Yip me toooO
Its the first time I have seen a wiseco +2cc flapjack
Old Nov 16, 2012 | 02:50 PM
97mm_EH3's Avatar
Sounds like you dropped a valve (stock, used) while getting an "over-rev" while shifting. What did you set the BC springs installed height to? It makes a difference. Also what is the REAL rpm number @ 8800 on your stock tach? I have seen them off by 1000 @ the top.
Old Nov 16, 2012 | 03:43 PM
Retired Moderator
^^ mines off as well.
just one of those things
Old Nov 17, 2012 | 09:11 AM
Originally Posted by C2K_TB_TEC
shyte happens every now again... some more than others..
The valve obviously contacted the piston, you must have lost cam/crank synch on cyl 3 somehow (valve spring could have "bound" or "float")
Check, the valve springs, retainers and cotters.. esp on cyl 3
How old are the valves?
Could have had something enter the intake (but only cyl 3??)
Cyl 3 usually runs the hottest..
Piston looks steam cleaned on intake side..
det, lean, ping ???
Check injector number 3
8800rpm on 240cc injectors.. on a 2lt with ctr cams???
the deformation of the piston was through valve "shrapnel" and excessive heat..
check plugs and cyl head chambers..
I think most likley order of events... Piston pin broke away from piston... eagle rod with pin pounded unattached piston into valve and chamber.. could have been through lack of piston oiling at pin areas (pin lock up - siezed) and excessive friction and heat... the rest followed
The valves are not new, ie used b16 valves. They are still in the head but i can have removed to inspect..
Basically what happened at the begining of the build is i originally had a oem Honda belt on this build with BC0013 instead of ctr cams along with new brian crower valves.With 200 kms on the engine the brand new honda belt snapped resulting in all my new bc valves being bent. The tuner investigated and explained that the new bc valve springs ere too stiff/tight for a oem honda belt to handle. This is why he informed me to get a Gates belt.
Old Nov 17, 2012 | 09:15 AM
Im not surprised you didnt ask this on myhonda poser dc2 and rex forum lol..
I assume you have a sealed vc, with no adj cam gears..?
If it was a valvetrain issue that started the destruction.... then
CTR cams and those buddy club or brian crower vspring do not call for the blue belt..
Unless those are the high "rate" brian crower vspring's but even so, the cams dont have the lift, duration and ramp to warrant a blue belt..
"Honda" dont/didnt use bc vsprings nor the blue belt with CTR cams...
Nevertheless... paper... rock... scissors.... in this case "blue belt" > oem valves > wiseco forged pistons.... unless it snapped tooO..
yes my valve cover is closed and i do have adjustable Brian Crower cam gears.
The belt hasnt snapped
Old Nov 17, 2012 | 09:20 AM
if the valve dropped would it not have put a hole in the piston?
I am not sure about the install height i will have to check with my tuner.
Also i would need to doule check whete limiter was set on the management.
Would this build not handle 9000rpm?
Old Nov 17, 2012 | 06:01 PM
Garrett's Avatar
have you ever dynoed this engine?
b20vtec with Type R/CTR cams don't keep power up to 8800 rpm.
you drop a valves, probleme with valves to valve, valves to pistons clearance, or problem with retainers lock or broke valve spring
Old Nov 18, 2012 | 11:13 PM
Many have run the black belt without stiff vsprings and even race spec cams no issues..
Did you ask Jakes what he thinks about what could have happened?
yes, his explanation was that the new BC Springs were too stiff/ tight for an oem honda belt. does this sound right?
Old Nov 18, 2012 | 11:15 PM
yes i have dynoed the engine, even though it might not have kept power
up to 8800rpm, thats where it had been tuned to. surely the tuner would have set the limiter to a lower rpm if it was dangerous to go higher?
Old Nov 19, 2012 | 12:41 AM
ek4serge's Avatar
Dang that looked like it hurt !
b20vtecbruh
Jan 6, 2016 05:45 PM
blu3g
Feb 22, 2008 06:45 PM
84DA69
Nov 24, 2006 02:05 PM
jdmoutkast
Aug 21, 2005 11:31 AM
Maximus
Mar 1, 2002 06:03 PM
