Car alarm questions
Old Nov 15, 2012 | 10:23 PM
Hunterford93's Avatar
Default Car alarm questions
Hi I recently got a 1990 honda accord and I want to put a car alarm in it I just want to know if ill need anything extra like extra wiring harnesses diodes and/or resistors if so can you let me know it would be a great help!!!!
Old Nov 17, 2012 | 03:41 AM
a1alimo's Avatar
Default Re: Car alarm questions
HI dude get your car to audio installation service center near your residence , they will guide you in better way . because nowdays wirless alarms in market.
Old Nov 17, 2012 | 07:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
You going to install it yourself? Is that why you are asking?
1990 Accord is very basic. You shouldn't need anything else.
Old Nov 17, 2012 | 01:35 PM
BrotherAli's Avatar
Main wires:
http://www.cb7tuner.com/vbb/showthre...t=97949&page=2
Other wires, this one has color codes but also the locations of the wires which helps
http://carwires.tripod.com/wireindex.html
This should help you get started
While your doing it consider getting a backup battery and hiding the brain in a hard to find location.
Old Nov 17, 2012 | 04:48 PM
Aau's Avatar
Aau
pretty much basic wiring but if u don't know ur way around installing take it to a good shop, usually they charge 100-150 if u bring ur own alarm, if u don't have power locks u may be able to talk them into dropping the price a bit more
all u really wanna diy all u need to hook up is ur power, ignition, start kill, parking lights, door trigger, and power locks if u have power door locks
Old Nov 19, 2012 | 05:44 AM
No I'm not planning on doing it my self I'm going to get it professionally installed the guy told me to provide my own alarm and all addinal parts that are required; I'm planning on being able to pop the trunk with the remote and I'd like to know if I'd need an extra relay or something that's all. And where is a good place to hide the kill switch and the brain.
Thanks guys for all the help!
Old Nov 19, 2012 | 06:16 AM
BrotherAli's Avatar
Should have just said that in the first post. Anyways, yes with trunk pop you will need an actuator and a relay. If you want you domelight to come on when you arm/disarm then you will need another relay for that.
Old Nov 19, 2012 | 07:54 AM
Axatax's Avatar
What does this mean?? Guide you in better ways than what, exactly?
Old Nov 19, 2012 | 02:49 PM
Aau's Avatar
Aau
why not tell the installer what u want done and see what else u need to buy so he don't give u that "u need to buy this from us" scenario
as for the trunk u may need a solenoid instead of an actuator, b/c it may not be strong enough to pull the trunk latch, if it is then u might be able to use an actuator
NerfGunner420
Audio / Security / Video
Jul 5, 2014 09:34 PM
jayzeno
Jul 16, 2011 07:39 PM
shinji2787
Mar 8, 2010 08:25 PM
96lewd
Aug 2, 2005 02:16 PM
