Does the crank pulley have a harmonic dampener?
Old Oct 18, 2002 | 01:12 PM
Jsracingintegra
Guest
Posts: n/a
Default Does the crank pulley have a harmonic dampener?
Old Oct 18, 2002 | 01:14 PM
Shark Tank's Avatar
Default Re: Does the crank pulley have a harmonic dampener? (Jsracingintegra)
yes, you talking about the stock one right?
Old Oct 18, 2002 | 01:17 PM
Chris N's Avatar
Default Re: Does the crank pulley have a harmonic dampener? (CART fan)
Stock one does, yes.
Old Oct 18, 2002 | 01:18 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: Does the crank pulley have a harmonic dampener? (1107)
Cart fan and 1107 thanks!
Old Oct 18, 2002 | 01:24 PM
RTW DC2R's Avatar
uhhhh...what the hell is a harmonic dampener?
Ryan, who does not know these things
Old Oct 18, 2002 | 01:26 PM
Shark Tank's Avatar
Default Re: Does the crank pulley have a harmonic dampener? (RTW DC2)
supposedly stops harmonic vibrations from the crank
Philly_NBP_R's Avatar
cancels the second and third degree harmonic vibrations generated by the motor...
if it was a straight six or v12 it wouldn't need one
(engineers chime in here pleese)
Nick (who rode in an M3 today - straight six torque OWNZS)
Old Oct 18, 2002 | 01:46 PM
Rob :190:'s Avatar
Default Re: Does the crank pulley have a harmonic dampener? (Philly_NBP_R)
dont forget flat 6, Porsche OWNS
Old Oct 18, 2002 | 02:04 PM
Gansan's Avatar
Actually, it is needed by straight six engines (and by extension, V12) as well. BMWs have harmonic dampers on their crank pulleys. The torsional vibration that they damp is separate from the vibration caused by reciprocating and spinning parts.
[Modified by Gansan, 3:05 PM 10/18/2002]
Old Oct 18, 2002 | 02:11 PM
Tommy_Gunns's Avatar
Is that the N1 pulley? I thought the N1 pulley has no harmonic balancer.
Old Oct 18, 2002 | 02:31 PM
Shark Tank's Avatar
Default Re: Does the crank pulley have a harmonic dampener? (Tommy_Gunns)
n1= no harmonic balancer
stock = harmonic balancer
i think the pic is an n1
Old Oct 22, 2002 | 02:57 PM
myballs's Avatar
so can't u take of the dampener off the stock and put it on the UR one?
Old Oct 22, 2002 | 03:23 PM
Jsracingintegra
Guest
Posts: n/a
Default Re: Does the crank pulley have a harmonic dampener? (Sohroub)
no
Old Oct 22, 2002 | 03:40 PM
myballs's Avatar
well which part is the dampener? im lookin at a UR crank which is in my hands now, and it looks the same pretty much
Old Oct 22, 2002 | 03:45 PM
turbologist's Avatar
So is the OEM N1 pulley safe for ur engine? Seeing that it doesnt have a damper?
Is it worth buying?
Old Oct 22, 2002 | 03:50 PM
JustLooking's Avatar
Default Re: Does the crank pulley have a harmonic dampener? (drealboostedhybrid)
The purpose of the harmonic balancer is to absorb unwanted vibrations that the cranks gives off. With out the harmonic balancer the vibration will effect your oilpump and rod bearings making them wear out faster. This is why you don't want a knife edge crank for street purposes.
Old Oct 22, 2002 | 03:54 PM
RagingAngel's Avatar
It is the black rubber "donut" sandwiched between the outer (thicker) brasslike colored ring and the thinner silver colored ring.
[Modified by RagingAngel, 4:55 PM 10/22/2002]
Old Oct 22, 2002 | 04:00 PM
Dropspeed's Avatar
That looks like a stock pulley from the backside.
I have a stock ITR pulley that has been machined to keep the harmonic dampner intact and then balance. Removed aprox 2lbs from the pulley. there are only groves for the ALt belt, a/c and p/s have been removed.
I have one I can sell IM me
Old Oct 22, 2002 | 04:22 PM
Jsracingintegra
Guest
Posts: n/a
The UR crank doesn't have it, so don't use it.
Old Oct 22, 2002 | 04:39 PM
Steve's gonna have something to say about that..hahha....
DJNauTicz
May 2, 2007 11:31 AM
baphomet
Apr 13, 2005 12:35 PM
RAB
Oct 13, 2004 05:45 PM
airwalk07143
Sep 24, 2004 07:40 AM
Turbolude
Sep 12, 2001 05:53 PM
