stripped ball joints... help
Old Nov 15, 2012 | 06:10 AM
ghosthatch's Avatar
Default stripped ball joints... help
okay, so the ball joint threads are jacked and the factory crown nut wont thread on... i want to tow the car to the shop so i can start working on it but the control arm is gonna eat up the wheel if i do that...
so my question is... can i just use a different size nut like a standard size rather than metric and just use the gun to slam it up there? i need to replace the ball joints anyways
any other suggestions would be great. and if you know what size i should use please tell me that too :D
thanks
Old Nov 15, 2012 | 06:28 AM
Cheefer_EX's Avatar
Default Re: stripped ball joints... help
14mm nut and insert a cotter pin if you're worried about it loosening.
Old Nov 16, 2012 | 05:24 AM
ghosthatch's Avatar
the factory 14mm nut wont engage though
Old Nov 16, 2012 | 10:19 AM
Cheefer_EX's Avatar
well a 9/16" would be your next size. It's worth a try I guess. While you're at it, use some thread lock and that cotterpin. It's definitely a temporary/jury rigged solution though.
Old Nov 16, 2012 | 04:52 PM
ghosthatch's Avatar
its strictly to get it out of my driveway onto a tow bed and into the shop
Old Nov 16, 2012 | 05:38 PM
ekcoupeh22's Avatar
Put a floor jack under it and wheel it down the driveway...I've driven a tow truck for years done that hundreads of times for cars with broken ball joints. They also make a tool to hold it together which is pretty much a set of vise grips
Old Nov 16, 2012 | 06:59 PM
LS/Vtec-F.T.W's Avatar
take off ur steering knuckle get a nice sludge hammer and some c clip pliers if the c clip is there. Ive replaced many that didnt have the clip still intact. Just give it a couple smacks and itll pop out. Go get you a new one and lightyly tap it back in, and your problem is solved. I suggest getting it on lifetime warranty so you can get your other side replaced for FREE!!
EnjoyTheRideDC2
Suspension & Brakes
11
Dec 11, 2006 10:11 PM
EnjoyTheRideDC2
Nov 7, 2006 12:09 PM
PINKS
17
Apr 17, 2006 06:55 PM
DOMKID
Mar 17, 2004 12:31 AM
