D16Y8 engine swap
Old Nov 14, 2012 | 04:25 PM
floridasown's Avatar
Default D16Y8 engine swap
I have a 97 civic with the D16y8 engine. i threw a rod through the block and need to swap engines. I have been looking for the same engine but cant find anything. My question is what engines will bolt right in with minimal modifications?
Old Nov 14, 2012 | 09:28 PM
GIZZ - EXV's Avatar
Loved
Default Re: D16Y8 engine swap
You will have to swap some things over from your old y8 to a d16z6 if you want. Or go to a non vtec d16y7 but then ideally would need to get the matching ecu. A d15b7 will bolt in pretty easily, distributor will fit too iirc, just need to swap over the crank sensor stuff.
May as well just get the correct engine, expand your search area. Or time for a B swap.
Old Nov 15, 2012 | 01:23 PM
im new to hondas... what is a B swap? The d16z6 what are some of the things to swap over?
Old Dec 18, 2012 | 08:51 PM
shikka7's Avatar
Bigger engine sweeheart
Posted from Honda-tech.com App for Android
Old Dec 18, 2012 | 08:52 PM
shikka7's Avatar
Oh and more ponies;D
Old Dec 19, 2012 | 06:04 PM
B20dcteg's Avatar
You can get a jdm d15b from an engine importer for about 900 and it will be direct bolt up and plug and play but id go with a dohc swap more bang for your buck
Old Dec 19, 2012 | 06:11 PM
PhilStubbs's Avatar
A D15b is not a direct swap. Sure it will bolt into the car, but there are a lot of obd2 things that would need to be taken care of. It can be done, but sounds over this guys head. I say try to find a y8 or y7. You will have to change the ecu if you go y7.
Old Dec 19, 2012 | 06:55 PM
B_Swapped93's Avatar
find a Y7 block(easy to find) throw a Z6/Y8 head on it if you want the fastest route.
Colton Walford
Jul 22, 2018 10:38 AM
jdmlover714
Dec 21, 2011 12:31 PM
'91CivicSi
Nov 29, 2006 10:04 AM
bluedelsol
Aug 23, 2002 08:06 PM
