type r need help???
so i want alittle for power from type r b18c. so im thinking of ordering skunk 2 cams stage 3 pro series, pro series valves and springs. first question for my valves do i need stander-ed size or high compression valves.second question do i need to chance anything else and can my motor take this with upgrading the bottom end of the engine. also im ordering intake 74mm throttle body and fuel rails and a 3in exhaust.
Pro3 is much to big for a stockish compression and bore type r motor. Try pro1. You wont be disapointed with that. With that said you dont need to do anything besides valvesprings and retainers. I would recamend a 2.5 or 3 inch exhaust. And a 68mm throttle body and definitely a tune. Also dont replace your fuel rail. Your stock one is fine.
i suppose, but not the pro series stage 2. s2s2 , s2s3, s2p1 would all do you fine. i would personally use the pro1's. but thats just me.
or if you can swing it... custom cams. theres a few dealers around here that would love your business
If you want that much power your going to have to do more research. There is loads of info on here that you can search for. Go to the all motor dyno thread and look for the power numbers your looking for and check out there builds. To get an all motor b series to 250 or 300 whp your going to need atleast 2.0 liters if not more. And some very good port work and possibly custome parts. Ether way you have a lot of learning to do before you get into this.
250-300hp? and $3k ti invest? only way to get there would be forced induction...A bolt on kit would net that power range, and so would a JRSC if you could get your hands on one.
All in all though it sounds like you need to do as "angryhillbilly" mentioned.
If you really want to make power and not slap your self after spending all that money going all motor and you only make 200hp. Ask anyone going all motor is the expensive way to go slow.
Your best bet is to get a turbo kit and tune the motor and have fun with 300hp or get a Jackson supercharger and tune it and end up with 230-250hp.
You will need to do do a complete rebuild to reach 250hp all motor! im talking about a 2.0-2.1l block, ported head, good header and cams.ect ect. Want to call it a day just go boost. imo just put a JRSC on the stock motor and get it tuned on 6psi and have fun. or turbo it.
Those cams will never "just give you power!" whats the rest of the motor consist of? stock header? intake? stage 2 sk2 cams are much to big for a semi stock ITR motor. I would recomend a set of sk2 tuner 1 or maybe!! tuner 2 cams! depending on what other suporting mods you have.
But if he wanted peoples opinion on I/H/E I would recamend he ask. Or share his current setup.
For immediate gratification...im going to assume your on a stock P73 ECU. Just spend the money on finishing your basic I/H/E combo and invest in your transmission.
Gratification= trans with LSD and 4.9 final
Sweet! you already have a trans...4.4final? or 4.785? even this little mod is a night and day difference. Are you just after the 250HP as a benchmark number? or are you after something that feels and drives like it has some *****?
A 175whp itr with 4.9 final drive trans will feel and outperform a 200whp itr with 4.4 final. This is neither here nor there but i wanted to elaborate on the difference of a HP number and the actual feeling when driving something with less power but with aggressive gearing...
Back to your question...It would cost as much as selling your B and going K.
With the K you can attain 250 with bolt-ons and a tune. Beat up on it and not worry.
what is the car used for? track racing? drag? just a fun street toy? Daily driver?
how far into this rabbit hole do you want to go to get your power numbers?
are you willing to rebuild the entire motor? possibly sleeve it? stroke it? change pistons?
port and polish?
Do you even know what 250whp all motor feels like? or are you just throwing out a random number that is mad tight yo?
if all you want is to add some good power to your ITR motor and make it more bawlsy. you can just build the head. PNP, 68-70mm TB, peformerX intake manifold or skunk2 pro, pro1 cams, pro series flat faced valves and valve train, a better header like toda or smsp or hytech, and a matching 2.5-3" exhaust. and of course a good Dyno tune!!!
(i think the Pro1 cams will make you more over all power than the tuner stage 2's)
GLWB
port and polish?
GLWB
its just street toy but i was thinking of putting skunk 2 tuner series stage 2 cams with skunk 2 Tuner Series Valve Springs,Pro Series Valve Set not sure what i need Standard Compression or high compression and skunk 2 Titanium Retainer Set, skunk 2 intake trottle body and fuel rails and of course its getting a full tune by a well know shop. anyone think this is going to make some jam
hndacord02
Sep 6, 2007 08:18 PM
Project-D
Aug 6, 2006 09:03 AM
