Is my motor mount bad?
Old Nov 13, 2012 | 05:15 PM
FearSC549's Avatar
Default Is my motor mount bad?
First part is in 1st gear and from 0:36 is in reverse. The right transmission mount has some flakes from the mount, but I don't see any cracks. I haven't had time to check the other mounts, but here's a vid. How does it look?
Is the car suppose to surge/jerk when in 1st and 2nd gear light acceleration and also in deceleration? I know my mainshaft bearing is bad, will it cause those symptoms too?
Old Nov 13, 2012 | 05:21 PM
Fliptard's Avatar
Default Re: Is my motor mount bad?
do you have torque mounts?
Old Nov 13, 2012 | 05:31 PM
FearSC549's Avatar
No, everything is original from factory.
Old Nov 13, 2012 | 05:35 PM
Fliptard's Avatar
so much fail, torque mounts come on every factory honda.
Ones bolts to front of trans and runs to under body of car, other one bolts to front of motor and runs the the other side under the car.
Google honda torque mounts and look thro images.
Old Nov 13, 2012 | 05:48 PM
FearSC549's Avatar
Oh, I thought torque mounts are solid mounts. I'm a noob.
Old Nov 13, 2012 | 06:26 PM
Fliptard's Avatar
they can be solid, if you buy them.
Old Nov 13, 2012 | 07:58 PM
dirty19's Avatar
Ridin Dirty in Cali
That looks like a bad torque mount to me.
OEM.
http://www.thepartsbin.com/images/pr.../h311512_1.jpg
These are after market. but i have seen them much cheaper than this.
http://realstreetperformance.com/sto...egra-2553.html
Old Nov 15, 2012 | 04:49 PM
1604169's Avatar
That much movement looks pretty normal to me. You can try carefully jacking up the motor by the oil pan to get a better look at the mounts to see if they're cracked. Use a block of wood on your jack or something so you don't hurt the pan.
Mccormick009
Nov 3, 2014 04:45 PM
ribal_gh
10
Nov 20, 2012 11:58 AM
rockcity
May 14, 2008 06:41 PM
lurkin' eg
Nov 30, 2007 03:48 PM
gsr336
Aug 14, 2007 04:57 PM
