98 integra leaking water when it rains!
My dc is leacking water in when it rains down by the ecu. Was wondering if anyone else has had this problem, and where should i be looking?
windshield is suspect. other suspect are the door seals but MUCH more common on the driver side than passenger.
lay in there with a light and watch when it's pouring. and or have buddies drench the car with 5 gal buckets of water
with ANY water problem you literally have to look and watch.
also check for weird **** like amp wire drill holes running around that area in the firewall that could be taking on water. just be through and look
bad 91 teg
33
Oct 1, 2011 02:34 PM
