On Cold Idle, Car Goes to 2k RPM, Drops, Repeats
Old Nov 12, 2012 | 07:13 PM
accord1986's Avatar
Default On Cold Idle, Car Goes to 2k RPM, Drops, Repeats
This pretty much says it all. Seems like when it's cold outside, I have a hard time starting it up - chokes a bit, and I have to give it gas. Once it's started up and still cold, the car will hit 2K RPM, then drops down to like 1500RPM, then goes up to 2K again, drops - repeats a whole bunch. Once I drive it and get warm, it's fine. Starts without issues, and the "sticky" RPM isn't there.
It's a 1994 Honda Accord
What do you think? IAC valve? Or something else. Something I need to take into the shop, or can I clean something myself? Sure sounds to me like something is just stuck or dirty, and needs a good clean.
Thanks!
Old Nov 13, 2012 | 04:03 AM
forted's Avatar
Default Re: On Cold Idle, Car Goes to 2k RPM, Drops, Repeats
Most likely you have a bad IAC valve. Slight chance it could be a vacuum leak.
Old Nov 13, 2012 | 07:31 AM
eirigance's Avatar
Your fast Idle valve would control that, not the iac. If your O2 is bad that would also do it. good luck
Posted from Honda-tech.com App for Android
self_made
Apr 10, 2021 02:25 AM
jaycapz
11
Jan 15, 2016 05:13 PM
95civic16
May 23, 2008 12:22 PM
devonic
Sep 26, 2003 08:55 AM
Petah
Jun 17, 2003 07:28 AM
