Car would start and die now wont start at all
Hey all im new to this forum and im in need of some help. I just got my car put back together, its a 93 Civic Hatch CX model 5 speed. Well any way i swapped out the old motor for a ZC block with a z6 head running a p28 ecu, It all started when i was driving down the freeway my check engine light came on then the car just died as if someone just shut the key off..
So im on the side of the freeway stuck i roll the car over it would start then die.. so i sit there 15 minutes hit they key and give it about 1/4 throttle it would run but if i let it idle same thing start and die.. So i get it home go to start it and nothing...
So far i have checked for CEL codes came out code 15, checked for fuel i have fuel I hear the main relay click twice Changed the icm and made sure the timing was dead on.. still nothing no spark, So any advice would be greatly appreciated. Thanks.
antonio1122
24
Sep 23, 2017 04:56 AM
