high compression b18c parts
hey ht amm im trying to put 2gether a high compression b18c
these are the parts that im currently looking
toda killer cams and rocker assemble
toda itb or similar set up
12.5comp standard b18c size pistons
vented valve cover and catch can set up
brake booster delete kit
s2k push start kit
and also s2k clutch master and spacer
decent b series exhaust manifold to go with the set up
amm also looking some hood dampers for eg
will add mre parts once i start to get deeper into the build
any and all help would be appreciated
thanks in advance
s2k push start kit
thanks in advance
ok guys found the toda itbs and a set of headers and also the vented valve cover set up and catch can
rlly need the toda vtec killer cams and hardware needed to run them hit me up guys
