Problem: Mothers 96 EX auto won't start.....
Old Oct 18, 2002 | 12:00 PM
*Boostwerks*'s Avatar
Default Problem: Mothers 96 EX auto won't start.....
It was working great last night.....???
But today when my mother tried to go to the store, the damn thing wouldn't start. All I can hear is the fuel pump priming and thats it.....NO starter turn.
The engine is full of oil, and visibly has no problems. I have checked most of the fuses and they are all OK.
WTF????
Any help?
To bad all my Honda knowledge is centered around Turbo's and CRX'S.....
Thanks
Bryson
Old Oct 18, 2002 | 12:36 PM
RotaryBzzz's Avatar
Default Re: Problem: Mothers 96 EX auto won't start..... (Bryson)
ignition switch.
edit: Or completely bad battery that's showing high voltage. Check the AMP drop with a multimeter when you crank the motor. Connect one prong to the negative terminal of the battery and one prong to the starter at the connection to the battery cable (if possible). It shouldn't fall below a 8 or 9 reading (i think that's the number...its been awhile). Check a manual...should have the right numbers. You could also try jumping the car with another car or a wall-charger. That would tell you right away if its the battery....
[Modified by RotaryBzzz, 2:31 PM 10/18/2002]
Old Oct 18, 2002 | 06:59 PM
Razor's Avatar
your 96 ex was probably affected by that ignition recall. honda will replace your ignition for free if you take it to the dealership.
Old Oct 18, 2002 | 11:46 PM
Default Re: Problem: Mothers 96 EX auto won't start..... (onetym408)
UPDATE:
Went to go start her up this morning, and.......starts right up.....
Didn't give any weird noise, stumble, or codes....just started right up.
WTF????????????
My mother has been driving all day, and she hasn't had anyproblems.
1993gsrcivic
Dec 2, 2008 10:30 AM
Wmartir123
Aug 7, 2006 06:09 AM
Rex_Ryder
Jun 21, 2005 10:30 PM
Propulsion
Mar 27, 2003 04:11 PM
tan2
Nov 4, 2002 10:10 AM
