No start
Finished boosting my car recently, my mods are as follows:
b18b
450cc DSM blue top injectors
Xenocron fuel pump
Crome tune
Gm 3 bar
Originally i have a Phearable basemap which the car ran on. (super rich)
Took my ecu to my tuner to have him upload a tune so i could get on the dyno. Now that car wont start. It turns over, sometimes sputters, but no start!
The only thing that has changed is the amount of fuel in my gas tank, and the tune on the ecu (still crome). My tuner suggested that since I'm low on gas the fuel pump isn't able to pressurize the rail enough to get the engine to turn over.
Is this possible? (I'd go try but the car is sitting in his garage still, going to bring it home tomorrow) It seems like the xenocron fuel pump would sit the same way in the tank, that the oem one does.
Here is the kicker though! I wired in the oem map sensor, and plugged in the stock ecu, and the car still won't start. So now i'm really puzzled.
Any help is appreciated.
b18b
Xenocron fuel pump
Crome tune
Gm 3 bar
What lights in your cluster come on/stay on with the key in the on position? Check for fuel pressure at the fuel filter. Is the pump priming? Can you hear it wine for 2 seconds when you turn the key to the on position?
The easiest thing to try first is putting in 5 gallons or so of fuel...and see if that cures the issue at least temporarily.
Lots of time we get reports from people that below a certain fuel level they have issues, which is usually caused by the fuel sock being put on incorrectly or loosely...or sometimes knocking it loose while installing it back into the tank.
Essentially if the fuel sock isnt put in the correct location to pick up fuel it wont be able to, or if air is able to get around where the sock connects to the fuel pump, you will get air in the lines.
Hope that helps...
Hope that helps...
b18b
Xenocron fuel pump
Crome tune
Gm 3 bar
b18b
Xenocron fuel pump
Crome tune
Gm 3 bar
Hope that helps...
Hope that helps...
Put some fuel in and the car fired right up!
rasinhell
17
Apr 19, 2005 02:09 PM
