Help: 2000 Civic dx power door conversion problem
Old Nov 11, 2012 | 01:41 PM
adnoH671's Avatar
10 Year Member
Default Delete Please
Please delete this thread, thank-you
Old Nov 11, 2012 | 05:41 PM
canadaek's Avatar
Default Re: Help: 2000 Civic dx power door conversion problem
some of our cars had heated mirrors that could be the extra wire's
Old Nov 13, 2012 | 06:48 AM
kyden's Avatar
99-00 usdm does not have the power lock module in the door like the canadian and usdm 96-98 civics.
Old Nov 13, 2012 | 08:31 AM
canadaek's Avatar
white with orange is defogger control , the blue with yellow is rf window control i can't tell do the other wire's have a strip on them ?
Old Nov 13, 2012 | 07:13 PM
adnoH671's Avatar
10 Year Member
That was my first general thought, any more info helps. Is there any further indication I can look at to see if I do have the wiring for the heated mirrors on my power door harness?
Where would the power door lock module be located in the 99-00 USDM Civics? I will look at the 99 Canadian SI harness to see if I am able to locate the module away from inside the door. Would it be just fine if it were inside the door?
I believe there is some slight mix up with the close up pictures. The red arrow doesn't point exactly at the two different wires it just indicates what side it is on(naming the photo was good enough indication). I will remove the pictures look through the wires and post up the exact wires that I need to have looked at. I apologize for the mix up...
Old Nov 14, 2012 | 08:33 AM
canadaek's Avatar
oh sorry ya if you give the wire colours i can look them up for you. and if you look at the plug in for the mirror if it has 5 wire's its for heated mirrors 3 wire is normal power mirror.
Old Nov 24, 2012 | 01:42 PM
adnoH671's Avatar
10 Year Member
Here are the pictures, it looks to be that I have heated power mirror wires. Question: Will I be able to hook up power mirrors to the harness?
Old Nov 24, 2012 | 02:02 PM
ExplicitJDM's Avatar
there's a post that have been posted on the same forum about how doing it correctly :p
Old Nov 25, 2012 | 04:19 PM
canadaek's Avatar
yes they will work but you might have to move the pin's around (bottom 3) i will post a diagram tomorrow.
Old Nov 27, 2012 | 03:54 AM
adnoH671's Avatar
10 Year Member
Doing what correctly, how to wire up the power adjustment mirrors?
That would be great if you can post that diagram, and a quick to link on how to run the wires if there are any and where they go, that would be great thank-you...
Old Nov 28, 2012 | 08:27 AM
canadaek's Avatar
hey sorry has been really busy at work hope this helps
Old Nov 28, 2012 | 12:36 PM
deschlong's Avatar
Oh look, I can change this
Loved
Community Favorite
You will also need the heated mirror switch and pigtail, and add the wires that reach to the junction at the doors. Pillage wiring from the donor harness you have. Obviously, also you will need the heated mirror glass and elements. I can find these for you if you want to PM me to discuss further.
Old May 1, 2013 | 06:23 AM
kyden's Avatar
I don't think you can plug the Canadian door harness in. Canadian cars iirc have the door lock module in the door vs the kickpanel on usdm cars.
Old May 1, 2013 | 08:38 PM
adnoH671's Avatar
10 Year Member
Default Re: Help: '00 Civic dx Power Door Conversion
It's quite alright, thank-you very much for the pic now I know exactly where to re-pin the wires around when I need to...
Right right, thanks I will let you know if I end up converting my mirrors as well...
*Update*
I have successfully plugged in the the '99 Civic SI floor harness into my 2000 Civic dx, and I am currently in the testing phase before I put everything back into place. Everything works so far but the power door locks; I am also still waiting on my power mirrors to arrive so I can test them as well. From the info I have accumulated so far and from kyden^; is that the 99-00 Civic EX/SI Door Lock Control Module is located in the driver side kick panel which is also connected to the main harness under the dash, is this true? Is there anyway I can use the existing power door lock control module that I have and wire it up to a power source and or to the floor harness to the other door so that I can get the them to work like the 96-98 OEM Civics? There has to be some kind of write up somewhere here...
BoostedxEk
May 22, 2013 10:22 AM
jason_v2
21
Mar 12, 2009 03:21 PM
junintegra2000
Jul 11, 2008 05:23 PM
Son99ek
Aug 18, 2006 01:05 PM
