Honda CR-V & Element 2WD & 4WD Element & CR-V
crv starts slow
Old Nov 11, 2012 | 05:31 AM
slicksam's Avatar
Default crv starts slow
I just wanted to see if anyone had this problem or found a fix for this issue.
Me and my dad purchase a 2008 CRV/AWD brand new at the same time. When we went to pick it up. There is only 1 thing I noticed different about the 2. When you start it up, my crv starts up perfect. The other Crv(dad) started up sluggish/slow, as if the battery was low. In 2009 I had the battery checked by Honda and they replaced it. I am not convinced it the battery, cause til this day, its still starts sluggish and I had the battery replaced again in 2010. Now in 2012, its acting up again.
There is no draw on the Crv.
Could it be that a stronger battery is required? CCA?
Any thoughts?
Old Nov 11, 2012 | 06:40 AM
LDForget's Avatar
Default Re: crv starts slow
does his battery have the same CCA as yours? or less? more? could be a poor connection from the battery to the starter. Id try running a booster cable just to find out. Could also be a ground issue. Try the boosters from the block to the negative on the battery as well.
Old Feb 10, 2013 | 08:58 AM
slicksam's Avatar
I know its been a long time.
CCA are the same. My neighbor also has the same issue with his 2007 CRV.
AccordJDM413
Jun 25, 2019 07:11 PM
b20hondacivic
Feb 5, 2013 07:50 PM
schueytenten
Oct 23, 2010 03:45 AM
Jonathan_ED3
May 20, 2004 01:44 PM
s2kkk
20
Apr 1, 2004 12:54 PM
