plz help a girl out!!!!!
it's a purge valve for the EVAP system. the EVAP system takes gasoline vapors from your gas tank, stores them in a charcoal canister, and lets the engine burn the vapors
the purge valve you need to replace lets the engine suck the vapors out of the charcoal canister.
It's part #7, unhook the two vacuum lines, pull the electrical connector off, and remove it from the bracket on the upper intake manifold.
Make sure the electrical wiring and vacuum hoses are not deteriorated or damaged, othwerwise the switch won't work.
CornDogg
18
Oct 16, 2012 05:13 PM
