usdm h22a4 to jdm h22
Old Nov 9, 2012 | 07:02 PM
rekserjdm's Avatar
Icon2 usdm h22a4 to jdm h22
hey whats up guys i got a quick question need some help i have a 99 honda prelude and blew my engine so i got a jdm h22 i was told many things on doing my swap but one thing im wondering is do i really need to change the oil pump from my usdm to my jdm or is there any tricks to it???
Old Nov 10, 2012 | 11:42 AM
snobordboy's Avatar
Moderator
Default Re: usdm h22a4 to jdm h22
If you look at both pumps, you will notice that the engine from your car has sensors on the oil pump, while the JDM engine does not. That is why you need to swap pumps. You may also need to switch some sensors from the block and head.
Old Nov 10, 2012 | 03:30 PM
rekserjdm's Avatar
what are the main things i should focus on while doing the swap?
Old Nov 10, 2012 | 07:11 PM
prelude1897's Avatar
oil pump, dizzy, motor harness, I think there's one more thing, but can't think of it right now
Old Nov 11, 2012 | 07:34 PM
rekserjdm's Avatar
will there be alot of problems with the harness
Old Nov 12, 2012 | 05:27 AM
if youre swapping over the harness, there shouldn't be any problems
Old Nov 12, 2012 | 06:56 AM
yroachy's Avatar
A4 oil pump, crank timing gear and crank sensor, injectors, dizzy and harness need to be swapped to the jdm motor. I think that's it.
EDIT: the lower timing cover may be different for Ye crank sensor, I can't remember.
Old Nov 12, 2012 | 12:03 PM
Bouckaroo's Avatar
Remove all the peripherals off your h22a4, then strip the h22a down to bare block and reinstall all the peripherals onto the jdm block. Swap over the h22a4 oil pump with sensors, switch out the crank pulley, the balance shaft pulley(these are important as the pick ups for the CKP sensor are on them), use the h22a4 timgin covers and alternator, starter etc. Then use your h22a4 dizzy, intake manifold(full intake mani including injectors and rail and what not.) do not try use the h22a injectors as they will fry out your ecu.
If you do all of this then you should be able to reuse your h22a4 harness and the swap should be plug and play. Other wise you are going to be in for conversion harness, chipped ecu, dizzy conversion wires, and an assortment of other fuckshow around thigns.
I did this swap a number of years ago and i found it was very easy to do. This way i jsut described is also how i swapped my h23vtec, albeit it is built up and tuned with AEM sereis 2, but everything else was bolt on. Go on preludepower and you can read many many cases of h22a swaps.
If you keep your h22a dizzy and oil pump and intake manifold you are going to be up **** creeek with no ecu....er paddle.
Old Sep 15, 2014 | 07:02 AM
D3RBY LUD3R's Avatar
I have a 99 lude im taking out the h22a4 it came with and putting in an h22a seeing that ill have to swap oip pump, crank sensor, distributor, injectors, motor harness, crank timing gear, etc is kinda discouraging if i wete notto swap that stuff but rather get a conversion harnesd, chipped ecu, dizzy coversion, what else would i need?
Old Sep 25, 2014 | 06:48 PM
thomas's96vetec's Avatar
if you wana leave the h22 as is you will need to get a obd2a to obd1 jumper harness or if its a 99 and up obd2b to obd1 and find a p13 ecu (correct me some one if im wrong) or get an p28 have it chipped and tuned , and unless your car is an auto the you will have to change all of it over
ProjectEg93
Apr 28, 2017 04:01 PM
drbenne
Sep 16, 2014 03:29 PM
bryannico001
Jul 18, 2013 11:45 PM
2kgs-R
Mar 6, 2007 08:36 AM
99_SH
Nov 24, 2005 02:44 AM
