Transmission & Drivetrain Gearboxes, Differentials, Clutches
Limited slip conversion
Old Nov 9, 2012 | 12:29 PM
salaamq's Avatar
Default Limited slip conversion
So, I was looking around for diffs on ebay, and I found this.
http://www.ebay.com/itm/250915233189
How does that work?
Old Nov 9, 2012 | 02:12 PM
94EG8's Avatar
Seagull Management
Default Re: Limited slip conversion
Originally Posted by salaamq
How does that work?
Poorly...
That's a piece of junk and doesn't really do anything. If you want an LSD buy a real one from MFactory or Quafie.
Old Nov 9, 2012 | 03:05 PM
sxysweed's Avatar
If you talk to Bone, he knows a company that does that correctly.
Old Nov 9, 2012 | 03:31 PM
salaamq's Avatar
It looks more like it would make a locked diff than a limited slip.....
How exactly does that gadget work? Cause it doesn't make it a mechanical, clutch, or fluid limited slip....
Old Nov 11, 2012 | 10:03 PM
sxysweed's Avatar
The premise is that the gears are pushed apart against the casing so it works like a clutch-type LSD. Doesn't work without the clutch plates though (but like I said, Bone knows a company that will turn a stock diff into a clutch-type LSD, the works similar to how the linked one should).
Civic HX 121
Jul 2, 2012 09:06 AM
b16a4
Suspension & Brakes
Mar 1, 2007 06:57 PM
Chiller
Feb 20, 2006 02:05 AM
KFBhonda
Mar 4, 2005 02:48 PM
goforbroke
Jul 12, 2004 07:27 PM
